P0116 Woes - The Saab Link Forums
Old 01-24-2016, 10:59 AM   #1
jpgroth's Avatar
P0116 Woes
Hola. I bought a '02 vig in October. Ever since I bought it, the coolant temp would never ride over 8:00/8:30 on the gauge. I finally got around to flushing the coolant and replacing the tstat/coolant temp sensor about a month ago. As it got colder out the temp gauge wouldn't rise above 7:30. If cruising on the highway and ambient temps were below 35 degrees or lower the gauge plummeted, dead cold. Both before and after replacing the tstat/temp sensor. The car started throwing the cel about a week ago. I researched more and was told I replaced the temp sensor with the wrong part. I switched it the other day to the longer, skinnier sensor with the black end. But no difference. I'm stumped. How do I test the wiring on the temp sensor?
Sent from my iPhone using Tapatalk
jpgroth is offline
Old 01-24-2016, 11:05 AM   #2
This sounds dumb, but are your fans stuck on? Is your climate control cycling the AC?
Does the heat blow warm? If it does, then you have an electrical problem. If it blows cold, then you have a mechanical problem. Simple as that.
-Cm
Cm452 is offline
Old 01-24-2016, 11:11 AM   #3
jpgroth's Avatar
It blows warm. No difference in ACC. Shouldn't the tstat override the fan even its running all the time?
jpgroth is offline
Old 01-25-2016, 06:58 AM   #4
I meant hot; if it blows warm, or lukewarm, you have a mechanical problem, since the heat will blow warm-ish with the temp gauge at "cold". But if it blows hair-dryer hot or near that, the you definitely have a calibration problem with the sensors, or the wrong sensors.
-Cm
Cm452 is offline
Old 01-25-2016, 06:10 PM   #5
jpgroth's Avatar
Alright. I did some testing tonight. I turned the heat to HI when I started the car tonight. It blew hot. But as I drove the car down the street into cold air, the air turned cold. When I stopped at the lights, the heat blew warm..
jpgroth is offline
Old 01-25-2016, 06:11 PM   #6
jpgroth's Avatar
Same position on the tsat..8:00
jpgroth is offline
Old 01-25-2016, 08:41 PM   #7
Sounds like bad luck! That T stat should pop @180 or so, but not before. Sounds like a failed T-stat (they fail open, so as the car moves the temp drops)
I know you just put one in, but, the ECU cannot, TMK, control the actual coolant temperature beyond the fans. if the fans are NOT cycling, then you are allowing too much coolant into the radiator too early==classic sign of popped T-stat.
-Cm
Cm452 is offline
