Broken A/C compressor pulley removal - The Saab Link Forums
Old 08-17-2015, 08:37 AM   #1
Champ's Avatar
So my car started making this great rattling noise - I traced it down to the A/C compressor clutch going out.
After I ordered a new clutch kit, I took it apart. Turns out it was the pulley (broken) and that part of course you can't really buy without purchasing a new compressor ($$).
I went to U-pull and through some christmas miracle they had a Saab in the junkyard that had the pulley I needed.
So I have everything I need, but still have to retrieve the old inner part of the pulley that is still attached to the compressor...
Any ideas on how to get this out? The lip is very shallow, not sure a typical 2/3 jaw puller would be able to grab on. I think I will have to literally cut it off, trying not to damage.
Here are photos so everyone can be sympathetic for me:
This is the broken one, my finger is pointing to the inner portion of the pulley that broke at the spokes
This is the used one I got, you can see the bearing that should be coming out (I have a new bearing for it).
Champ is offline
Old 08-17-2015, 09:48 AM   #2
Wagon Shaggin'
Saabeh's Avatar
Ouch. Weld something to it? Give it a nice slice maybe.
Saabeh is offline
Old 08-17-2015, 11:08 AM   #3
Champ's Avatar
The welding approach seems to be the easiest, minus the fact I don't have a welder.
Might be time to invest in one!
Champ is offline
Old 08-17-2015, 03:17 PM   #4
Welding cast iron is not easy, not the right thing to learn on. Additionally, it will put more heat into the compressor case that it can stand.
Are you sure you can't still grab the back of what is left? Even a small bite may be enough to dislodge it. I would apply your favorite penetrating oil to the nose of the shaft and try a 3 arm puller first.
If that doesn't work I would just pull the compressor and use a split bearing puller on a bench or in a hydraulic press.
I don't think there is really that much holding it on beyond corrosion. You can apply some heat but I would not put much into it. A quick shot with MAPP gas torch, say 20 seconds might be just enough to break the bond. Then it should pull with medium force.
Scott Shure is offline
Old 08-18-2015, 05:42 AM   #5
Wagon Shaggin'
Saabeh's Avatar
True ^ didn't think about the material. Heat and a hammer, you can get it. These pulleys go on and off by hand.
Saabeh is offline
Old 08-18-2015, 06:41 AM   #6
Champ's Avatar
Eventually got it off last night although it took some doing.
I was not able to get enough lip to use the puller tool.
Ended up just using PB Blaster and heat, along with some little taps from a hammer. Lots of pulling and pushing, eventually it flung off.
Thanks for the tips guys!
Champ is offline
Old 08-18-2015, 06:42 AM   #7
Wagon Shaggin'
Saabeh's Avatar
That's good. I'll have to remember to be reasonably delicate with the pulley from now on so I don't break it.
Saabeh is offline
Old 08-18-2015, 07:20 AM   #8
Champ's Avatar
It's annoying you can get a whole new clutch, but the pulley is basically no where to be found - have to buy a whole new compressor.
Champ is offline
Old 08-20-2015, 05:58 AM   #9
Champ's Avatar
Update for people coming across this in the future:
I put the new bearing in a used pulley from the junk yard, and used the new clutch parts I got off of eBay.
I put everything back together and found the clutch was not engaging - I tried engaging it manually by applying 12v to the wire going into the coil and it was not energizing.
Took it all back apart, and found that the coating on the coil was not letting it ground to the compressor to complete the circuit. Had to rough up the coating on the back side a bit so it would touch metal to metal and turn on.
I recommend testing the coil before you put everything back together to make sure your circuit works!
Total cost <$100.
Champ is offline
