HELP! Failed DIC? Misfiring code & Very rough/sporadic idling - The Saab Link Forums
Old 08-16-2015, 05:16 PM   #1
Question HELP! Failed DIC? Misfiring code & Very rough/sporadic idling
Hey guys,
I spent the day swapping out my TD04-15t yesterday with a new one, because I thought the problem with my 96 900SE was the turbo. I had a rougher idle and smoke from burning oil (NOT coolant) from the tailpipe. My previous TD04 had a TON of in/out ("longitudinal") shaft play, and I figured it had finally given out, leading to terrible performance.
After a proper install yesterday, the problem remains the same. My car has a VERY rough idle, noticeably less braking power, and is just not doing well. It starts up every time and does not shut off on its own, although it did stall once while I was maneuvering the car so that I could get it onto a towtruck bed.
I scanned for codes and got: P0300 (random misfiring) and P1577.
I sprayed all the relevant vacuum and brake lines for a vacuum leak - found nothing. I used a smoker machine to look for vacuum leaks - found nothing. I let it sit and idle for literally 15-20 minutes, but the idle never improved.
Is this the DIC? I've never replaced the DIC in the 3-4 years I've had this engine, and I bought the DIC used from someone else when I got the engine. So, the DIC is definitely more than 5 years old, and probably substantially older than that.
My car's fuel pump is new, engine was rebuilt like 2-3 years ago, turbo is new, seals are new, oil and coolant are not leaking or burning, there are no vacuum leaks.
What are the odds this is the DIC?
I sincerely appreciate any help you guys can give me.
dougwentzel is offline
