Temp gauge stuck at zero - The Saab Link Forums
Old 08-03-2015, 06:31 AM   #1
turbocon86's Avatar
1999 Saab 9-3 2.0T base. The temp gauge has been stuck at zero for months. No CEL. I have not changed anything yet (t-stat or CTS). Looking for advice from anyone else who may have had a similar issue before diving in.
I'm wondering if this may be behind the AC clutch not engaging as well. I can get the clutch to engage if I jumper the relay. Fuses, relay, freon Levels and high/low pressures are within spec. Not sure if the ECU is not allowing the relay to fire because it can't get an engine temp signal.
1993 900T Comm Ed #3
1993 900T Comm Ed #249
1994 900T Comm Ed #363
turbocon86 is offline
Old 08-03-2015, 07:08 AM   #2
I'm fairly certain that the water temps sensor in the head causes this.
Good news? $11 part.
Bad news? WAY harder to replace than it should be.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 08-03-2015, 07:39 AM   #3
Wagon Shaggin'
Saabeh's Avatar
9-3 A/C clutches fail often apparently, people sell clutch kits for them.
Saabeh is offline
Old 08-03-2015, 12:45 PM   #4
turbocon86's Avatar
The clutch engages when I bypass the relay, so it's likely some programmed-in fail safe. Since I already checked the high and low pressure switches and the freon levels and pressures, it must be some other issue. I was told by my Saab mechanic friend (finally called me back) that if the ECU can't get an engine temp, it goes into safe mode.
I bought a CTS. We'll see if that works.
Old 08-04-2015, 03:32 AM   #5
Bad temp gauge should throw a CEL. It might be your cluster....
go to autozone and see if you have any pending codes. How is your gas mileage?
-Cm
Cm452 is offline
Old 08-04-2015, 07:45 AM   #6
turbocon86's Avatar
Put in a new CTS and all is well. Temp gauge and AC both working now. Thanks for the ideas.
Old 08-04-2015, 07:47 AM   #7
Wagon Shaggin'
Saabeh's Avatar
Nice! Easy fix.
Saabeh is offline
