2K viggen idle/running issues - The Saab Link Forums
Old 05-14-2015, 08:02 AM   #1
gm
gm's Avatar
My Viggen has been acting up recently
When the car idles the RPM's do not stay constant, it kinda lurches making the car shake a bit before it settles out again for a few seconds then lurches almost like a stall
For a while when accelerating partial throttle less then 50% the car also lurches and does not develop smooth power like it use to
When driving a few nights ago it was acting when cruising at a constant speed. I was only going 35mph and it would drop a mph or two before the power would come back.
Car is a 2K viggen, almost 156K miles
Any thoughts on what it could be? I was thinking of buying a new DI casette as well as a new mass air meter..... the mass air meter is 50-100K miles old, can't recall when it was swapped last. DI if I recall was replaced at 60K
I put new plugs in the car every 10K miles
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-14-2015, 09:33 AM   #2
Turbo00's Avatar
Start with the MAF. Surprising you aren't getting a code.
Turbo00 is offline
Old 05-14-2015, 10:10 AM   #3
Drew in Houston's Avatar
I'd do these in this order:
1. Check that MAF sensor is plugged in and contacts are clean, wire isn't damaged, etc., if ok
2. Check for any vacuum leaks including FPR reference line, and possible air delivery leaks like intercooler hose popped off or delivery pipe at throttle body partially popped off, if none
3. Trial a replacement throttle body
Drew in Houston is offline
Old 05-14-2015, 10:38 AM   #4
gm
gm's Avatar
Thanks for the input... I will look at those things a bit closer and start swapping parts. With the DI being old... Should I get a new one of those? I haven't been anywhere close to 100% throttle for many months due to how the car behaves
Yea... No codes...
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-14-2015, 06:18 PM   #5
Who knows for sure? I've had DI's fail a few different ways but not like you're describing; I have had throttle bodies do exactly like you're describing and pipes blown off and forgetting to plug the MAF back in give similar symptoms..
I'd guess it's one if those things, post up what you find though! Knowing how well yoy maintain things my bet is worn throttlebody.
Old 05-15-2015, 04:36 AM   #6
Turbo00's Avatar
Wow, didn't realize the TBs could be that big of a wear issue Drew. Good to know.
Turbo00 is offline
Old 05-15-2015, 10:47 AM   #7
gm
gm's Avatar
Going to look over the engine tonight.... and check for leaks
This evening I will order a new throttle body & a MAF since it's also old..... debating on a new DI just to be safe.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-15-2015, 01:37 PM   #8
Cark's Avatar
The DI's are so cheap now, I think it would be a good idea. Lots of people have bought them recently due to the low cost not thinking they needed one, then realized their car runs WAY better with the new DI!
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 05-15-2015, 03:04 PM   #9
gm
gm's Avatar
Before I buy the stuff... Any opinions on which DI I should get?
Eeuroparts has two options
Proparts at $199 .. Retail of $600 plus
Or
Oem Saab at $379, retail $440 ish
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-16-2015, 04:02 AM   #10
Cark's Avatar
Gary, there are deals on brand new OEM DI's for around $150-180 on rock auto, advance auto, auto zone. All of these sites offer coupon codes to save you a few bucks. They are usually listed as airtex/wells, but they are in fact showing up as brand new SEM parts, in most cases version E and very recent build dates.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 05-17-2015, 04:13 AM   #11
lms
Cheap/easy things first. Unplug maf and take it for a cruise, if it runs better, bingo. Replace plugs, cheap and easy. Like stated, check all around engine compartment for vacuum lines, ic hoses, etc... making sure they are not cracked, loose...
I wouldn't just go out and but a dic quite yet, do you know of someone that you can swap with, shop maybe?
lms is offline
Old 05-17-2015, 07:28 PM   #12
gm
gm's Avatar
Plugs have 5,500 miles on them... Been replacing the plugs every 10k-15k miles
I looked over the engine and everything looks fine. No loose or disconnected vac lines or ic hoses... All looks good
Dic - now that I think of it I think I have one in my garage. I swapped my DI last summer when the car wouldn't start and I do not believe I ever swapped it back. The one I have is probably 8-10 years old....
Mpg has also been not so great. I average 19-22 mpg now with zero full throttle runs and a mix of city/highway. I use to get 22-25 mpg with similar driving. The computer states 27-28 mpg highway
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-18-2015, 07:39 AM   #13
Legit's Avatar
Coolant temp sensor?
2002 Viggen Convertible
Legit is offline
Old 05-20-2015, 11:11 AM   #14
gm
gm's Avatar
would a bad coolant temp sensor cause my fans to turn on after 30 seconds of idling.... the turn on/off constantly
Been to busy at work thus haven't ben able to mess with the old saab
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 05-20-2015, 11:14 AM   #15
DrewP's Avatar
Mine will do that if the A/C compressor is set to come on and it's warm-ish out.
DrewP is offline
Old 06-08-2015, 10:45 AM   #16
gm
gm's Avatar
Haven't had a chance to work on the car at all.... had a busy few weeks at work.... last night I had a late evening at work & either my radiator let go or a coolant hose.... hopefully get a chance to work on the car this evening
Once I figure out what let go last night I will order the other parts to hopefully get the car running better
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 06-12-2015, 10:54 AM   #17
gm
gm's Avatar
Radiator sprung a leak.... what a complete PITA to install....
ended up just ordering a new AMM which is suppose to arrive today. Hopefully that will fix some of the running issues....
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 06-12-2015, 01:55 PM   #18
gm
gm's Avatar
AMM arrived... Is installed.... Running better but still not 100%
It's a lot smoother however there is still some hesitation when accelerating part throttle and it almost acts like it's going to die at times when I shift
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 06-13-2015, 06:42 AM   #19
What's the story with your bypass valve/BOV?
50% throttle sounds like EXACTLY the spot where a diaphram type bpv would flutter with zero-vacuum.
Do you use the solenoid or is there a line from the manifold to the valve?
I was having issues with mine. swapped to a metal piston-type that fits in the stock location, and ran the vacuum line straight to the manifold, and it was instantly worlds better.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 06-13-2015, 06:51 AM   #20
Did you already swap the radiator? Although it's a lot of parts, it's not terrible.
I'm convinced that you could remove it from the bay if you took the fans off first.
It's been forever since I've swapped one on a 9-3, though.
Make sure you buy a good-quality replacement. you Don't want to have to do this 2x
Craig R.
g96nt is offline
