Stripped Stanchion Arm Capture Nut..FML - The Saab Link Forums
Old 03-19-2015, 10:58 PM   #1
The threads were always sketchy and I guess this was the final straw. I tightened home the rear-stanchion arm bolt where it secured the rear of the subframe and heard a "tink" whereupon the bolt and threads simply fell out of the car. I was thinking that the best solution would be to get a grade-8 14X2 thread-pitch bolt to replace the 12X1.5 OE bolt. Will the capture-nut tolerate being drilled and tapped for a 14mm bolt? Does anyone have a better idea? I know I could helicoil, but, I don't like that stock bolt; the threads are too fine for all the sand and bullshit that gets tossed into that cavity.
#Saabbeingdumb
Thanks,
-Cm
P.S major consideration must be made for the fact that a helicoil requires a special drill and tap size. I don't want to buy this crap when I already have a 14X1.5-2 tap and die.
Cm452 is offline
Old 03-20-2015, 05:56 AM   #2
oliversexpedition's Avatar
If you can get to the nut, hit it with an impact hammer and knock it out. Get a longer proper grade nut and bolt set and replace it.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 03-20-2015, 06:02 AM   #3
I can't picture it. Is this the one that someone posted having to cut holes in the floor to get to?
I don't see what you'd have to lose by trying to drill/tap. worst-case; you have to do what was suggested, which is knock off the old nut and tack another one down.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 03-20-2015, 11:21 AM   #4
Yup
Cm452 is offline
Old 05-12-2015, 02:30 PM   #5
WSW
WSW's Avatar
Did you resolve this? Same thing happened to me today
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 05-12-2015, 04:01 PM   #6
The captured "nut" is simply a thick round "slab" of metal.
About 10mm thick and 25mm across. Is welded to the body with three (yea,just three) spot welds.
With plenty of cutting oil, a sharp tap and careful pressure, it should be possible to thread for either a threaded insert or simply upsize the bolt.
I've gone through the floor on a couple 9-3's when the spot welds have broken. Not a whole lot of fun!
I've used this sketch, but always seem to be "low" by an inch or so:
If you do go through the floor, think I'd try using a long drill bit and drill up from under to best ID the center of the hole needed to get into the area.
win_k is offline
Old 05-12-2015, 04:50 PM   #7
WSW
WSW's Avatar
Mine is on the drivers side. I'm thinking of re welding the original nut back on
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 05-15-2015, 01:44 PM   #8
WSW
WSW's Avatar
Welds on the nut broke so I rewelded it and jb welded the backside as I couldn't reach back there with the welder
Then I start screwing in the bolt and it won't tighten all the way, bull the bolt out and the top threads were pretty jacked up, ordered up 2 new bolts. Installed a new bolt and all is good now. I'm definitely going to start keeping spares of these bolts
99 Viggen
04 9-5 Aero Wagon
WSW is offline
