Saab 9-5 window off track? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab New 9-5 '10+ Forum > Car Problems? New 9-5 Only
Car Problems? New 9-5 Only If you're experiencing problems with your new 9-5, post your question in here.
Old 03-21-2013, 10:04 AM   #1
kalbers's Avatar
Wrong part of forum, oops.. can a mod please move this to old 9-5 problems section?
When I roll down the passenger side window it seems that it comes forward and does not stay in the normal downward motion. Off its track or broken roller? I havent rolled all the way down, just as far as in the pic because it comes forward pretty far. Its like only the front is going down. See pics and thanks for any advice. 1999 9-5
kalbers is offline
Old 03-21-2013, 11:26 AM   #2
Off track and a broken roller.
One of the little green rollers is probably broken or popped off the arm. You'll need to take the door card off and figure out if the roller is intact, or if you need another one.
Old 03-21-2013, 12:16 PM   #3
kalbers's Avatar
Thanks Mike, I'll take a look at it.
kalbers is offline
Old 03-21-2013, 12:33 PM   #4
Yes, the other side wont be too far off either get 4 or more when you order.
Old 03-21-2013, 12:38 PM   #5
THIS, x2....
The rollers tend to be like headlights and taillights. They usually fail fairly close to each other.
Old 03-21-2013, 01:39 PM   #6
kalbers's Avatar
Originally Posted by mike saunders View Post
THIS, x2....
Oh fantastic, well at least I got a heads up! Thanks again.
kalbers is offline
Old 03-21-2013, 05:35 PM   #7
srp
srp's Avatar
Send a message via AIM to srp
Takes a decent amount of pressure to seat the new rollers as well. I used channel locks and it felt like i was going to break them until they seated.
srp is offline
Old 03-23-2013, 06:49 AM   #8
bergie's Avatar
yeah stock up on the green rollers and clean & re-grease them so there not noisy and sound like there rolling on sandpaper.. ALSO take a look at the seals around the glass. If the glass panel is not seated right in its rubber sliders seals or not put back in properly you will get water and eventual ice build up if its cold enough. this is mostly what kills your rollers, which is your problem.
bergie is offline
Old 04-19-2013, 04:12 AM   #9
SOAB's Avatar
Hope yall don't mind me bumping this but if one side of the tracks is bent about 90 degrees is that something I could take out of the car and straighten or is that a lost cause?
until something like this is available for saabs, there will be no slammage.
SOAB is offline
Old 04-19-2013, 10:16 AM   #10
jssaab's Avatar
what "tracks?" the cross piece of the regulator ( and I hope you are talkign about a OG 9-5 this is the NG section ( even tho the OP was talking OG as well)
jssaab is offline
Old 04-21-2013, 08:42 AM   #11
SOAB's Avatar
Sorry, didn't realize this was the new gen forum, but yeah Ive got an og 9-5. The last inch or two where the roller is completely bent.
SOAB is offline
