2011 9-5, I am finding water in the trunk. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab New 9-5 '10+ Forum > Car Problems? New 9-5 Only
Car Problems? New 9-5 Only If you're experiencing problems with your new 9-5, post your question in here.
Old 05-19-2012, 06:35 AM   #1
Last week I noticed that there was about three inches of water in the spare tire compartment of the trunk. I cleaned it all out and dried it up, the following day it rained so I checked the compartment again to find water about 1/2 inch deep. I could not find any wet spots in the carpeting above the compartment or find where the leak was coming from. Does anyone have any ideas?
Thanks,
Steve
2009 9-7x
2011 9-5
steveo66 is offline
Old 05-19-2012, 07:20 AM   #2
Drew in Houston's Avatar
Water in the trunk can be a tough one to figure out. Especially on a car with a small experience base.
Because of the large amount of water I'm gonna spin the wheel and say: Check the sun roof drains first (If you have a sunroof that is. Otherwise stop reading now and wait for a better answer lol).
Typically car makers will use sort of a labyrinth style seal arrangement on the glass/body meeting area, meaning that they expect the water to leak past an outer seal, fill a trough that's lower than the secondary interior seal, then drain away. So the 'drain away' part is handled by flexible drain lines on all 4 corners of the sunroof that travel to their respective corners of the car. The rear two probably follow the body/roof lines down and exit in the corners of the trunk through the floor. I've seen it on different models as well as older Saabs, but those tubes can pop out and dump the sunroof drains into the interior...leaving no sign of a leak anywhere but tons of water in the trunk. Those lines also get clogged too, then the symptoms are leaks when you happen to park on a hill with the clogged line on the downhill side and it happens to rain.
Pull back the trunk liner and look for a hose/tube that's supposed to be inserted into a rubber gromet but is not. One in each corner. If you're not up for that, park with the rear of the car facing uphill and then put a garden hose on it.
...of course it could totally be something else. Next you would have to start checking things like fuel filler door gaskets. Good luck. Hopefully someone else has a better answer and will pipe in.
Drew in Houston is offline
Old 05-19-2012, 04:58 PM   #3
jk88's Avatar
Paging JLausch. I believe his parent's car had this problem.
jk88 is offline
Old 07-01-2012, 01:25 PM   #4
I fixed it myself, the drain hose was not connected in the trunk by the corner lights. I had to take all of the panels out of the trunk so that they could dry to get rid of the smell. It took about a half hour each for me to take apart and put it back together, I did wait about two days for everything to dry before putting it back together.
Thanks for the help!!
Steve
2009- 9-7x
2011- 9-5
steveo66 is offline
Old 07-02-2012, 08:06 PM   #5
JLausch's Avatar
Send a message via AIM to JLausch
Just saw this now, sorry I didn't chime in lol
'03 9-5 Aero wagon
'91 9000t (sold)
'90 SPG (sold)
'01 Viggen (sold)
JLausch is offline
Old 07-02-2012, 10:04 PM   #6
Yikes...you'd think they'd learn.
This was a problem in the NG900....
Old 01-20-2013, 11:32 PM   #7
Stevo, by chance would you have pictures of where this hose is located? Would love to check it on mine.
Imspace2 is offline
