Tire Pressure Sensor Wrongly Going Off - The Saab Link Forums
Go Back   The Saab Link Forums > Saab New 9-3 '03+ Forum > Car Problems? New 9-3 Only
Car Problems? New 9-3 Only If you're experiencing problems with your new 9-3 post your questions in here. CEL Code or GTFO!
Old 10-10-2010, 01:24 PM   #1
ERP
ERP's Avatar
Send a message via AIM to ERP
17k miles on the Turbo X and the driver’s rear tire pressure sensor is showing low pressure, but my gauge is showing 36 psi. All four tires are around 36 psi. This is my first car with a tire pressure sensors, is this kind of thing common? Any other possibilities besides broken or dead battery? Anyone know the pressure threshold which sets off the sensors?
2005 9-2x Aero Stg 2
1996 900 'Aero' 2.3t Sold -
ERP is offline
Old 10-11-2010, 04:10 AM   #2
BurnsSide42's Avatar
They will set off if only off by a few PSI - however they are a common GM failure item. Take it to the dealer and let them diag it - probably needs a new sensor and a calibrate if it does not calibrate for them. This is what warranty is for - now go! lol
Check out
for your repair needs
BurnsSide42 is offline
Old 10-14-2010, 08:59 PM   #3
Curlymurt's Avatar
Mine go off around 33psi. I don't know if that's wrong or not. I keep the tires with more pressure anyway because they ride better and more efficiently.
I would say 36psi shouldn't be causing the low pressure warning.
Updated 04/02/2010:
'04 9-3 Aero
Curlymurt is offline
Old 10-14-2010, 09:01 PM   #4
jk88's Avatar
I had a problem with these on an 05 Infiniti. Couple trips to the dealer for a reset and it never came back.
jk88 is offline
Old 10-15-2010, 04:26 AM   #5
Harvey's Autohaus's Avatar
I've found this problem Over & Over again with the Sports sedan monitors. The Fix from GM as of 08 was to set tham all to 40psi. They might have a New Better fix but 40psi has always worked for me.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 10-15-2010, 06:39 AM   #6
ERP
ERP's Avatar
This is what I did a few days ago. I set all tires to 40 psi. It then took a few days but the low pressure warning light eventually went off.
ERP is offline
Old 10-15-2010, 07:39 AM   #7
May need a new sensor, we stocked these at Infiniti and they went from time to time.
