2006 9-3 aero v6 2.8L (manual transmission)
1.1K views 2 replies 2 participants last post by  briank3nney
My driver's side window has begun to only roll up approx a third of the way and then it immediately will automatically roll itself down. This only happens when I am parked or if I am going at an extremely low rate of speed. As soon as I get the car moving above 20mph it will roll all the way up.
I am at a loss for any sort of explanation.
I am in need of a fuel pressure regulator and I'm having it serviced soon. I know that this can effect mpg's as well as cause the car to sputter occasionally when shifting at higher speeds. I cannot imagine the two issues being related but stranger things have happened.
Any input, suggestions or ideas would be greatly appreciated. It's more likely than not an issue that my mechanic will fix anyway but I would still like to go in there knowing what is wrong and having a general idea of the cost.
Thanks in advance for any help you can provide!
Sent from my SM-S327VL using Tapatalk
Hey, not sure if you got your window up by now or not. If you hold down the child safety window lock button while putting the window up, it should go back up. This bypasses the pinch sensor, which may be your issue with the window. It's a quick fix, but not a permanent one.
