86 SPG problems - The Saab Link Forums
Old 06-26-2011, 08:01 PM   #1
Legit's Avatar
86 SPG problems
I managed to break my AMM, and obviously it doesn't idle well.
When driving it now, when I give it gas in 2nd gear, it builds boost, but does not accelerate. When I let off the gas, I hear compressor surge. I replaced all the vacuum lines, including the one on the BPV. I replaced the spark plugs with Bosch platinums and the wires with BWD super mags. Maybe its a bad ignition setup?
EDIT: Engine light is on, I'll get it read tomorrow.
2002 Viggen Convertible
Legit is offline
Old 06-27-2011, 07:47 AM   #2
mike d's Avatar
well, have you replaced the AMM yet? and has all this happened since the AMM failure?
could be a fuel pump, they do funny things when they fail
MikeDTuning.com
mike d is offline
Old 06-27-2011, 09:12 AM   #3
Legit's Avatar
Not yet, for now I have it unplugged.
Legit is offline
Old 06-27-2011, 09:53 AM   #4
DeLorean's Avatar
It is doing this because you have a broken or disconnected mass air flow meter. The car is in LHM, and this is just about the only to get an LH 2.2 car to have a CEL.
You should replace your air flow meter as step 1, there is no way a car will run properly like this, regardless of any other issues it has.
DeLorean is offline
Old 06-27-2011, 10:28 AM   #5
JK
JK's Avatar
Why would you bother having the code read, and who would you have read it? It isn't something you can take to autozone to have read. The car isn't even close to OBD2 compliant. And like DeLorean said, these cars won't run right at all with a bad AMM, so you already know what's wrong
If you want an AMM, I think I might have one in the garage, $20 and its yours, as long as it works.
If not, Palmer might too.
Like this, but used, not rebuilt
eEuroparts - Air Mass Meter (rebuilt) - # 8818296R
always a SAAB guy at heart
JK is offline
Old 06-27-2011, 11:03 AM   #6
Legit's Avatar
I'm getting one from a friend tonight, I'll update after I try that one out.
Legit is offline
Old 06-27-2011, 01:16 PM   #7
Yeah do that. Mine was bad and so was the bad one I put on it. 3rd one got it running like a champ again.
Old 06-27-2011, 02:13 PM   #8
Legit's Avatar
Would a bad AMM cause compressor surge?
Legit is offline
Old 06-27-2011, 02:20 PM   #9
Originally Posted by Legit View Post
2k on just the car. I'd be willing to throw 5k TOTAL at it.
Yes, I have mechanical ability.
How dare you doubt me.
Topher is offline
Old 06-27-2011, 04:54 PM   #10
Legit's Avatar
Yeah yeah.
Legit is offline
Old 06-27-2011, 06:01 PM   #11
Legit's Avatar
Tried 1st AMM, did not start
Tried 2nd AMM, did not start
Tried 3rd AMM, started and boosted perfectly
Legit is offline
Old 06-27-2011, 08:01 PM   #12
amish_geek's Avatar
Yay!
Saabs rule.
amish_geek is offline
Old 06-27-2011, 08:30 PM   #13
Legit's Avatar
Unfortunately the AMM that worked was the one in my friends 85 900.
Legit is offline
Old 06-28-2011, 06:54 AM   #14
DeLorean's Avatar
well buy a rebuilt one off eeuroparts or PM Me or JK, - I have working ones. or just buy a rebuilt one from eeuroparts.
DeLorean is offline
Old 06-28-2011, 01:38 PM   #15
Moreboost's Avatar
What are the normal symptoms for a failing amm?
Moreboost is offline
Old 06-28-2011, 02:19 PM   #16
Legit's Avatar
I think its the bad idle and LHM. Misfires under boost etc. I can drive it just fine if the gauge does not hit yellow.
Legit is offline
Old 06-28-2011, 02:21 PM   #17
Deez Nutz
Palmer's Avatar
I don't have an extra AMM.
S55/LC100/KL
Palmer is offline
Old 06-28-2011, 09:23 PM   #18
Legit's Avatar
I don't want to make a seperate WTB thread, I need a WORKING AMM asap. Part number 280-212-005
Legit is offline
Old 06-29-2011, 07:55 AM   #19
IronJoe's Avatar
I have a rebuilt/recalibrated one. PM me an offer.
IronJoe is offline
