second gear grinds - The Saab Link Forums
Old 02-15-2009, 08:29 PM   #1
second gear grinds
hello all im a newbie to this forum and still dont own a saab but have found one i would like to purchase its a 2dr 89 EFI non turbo 3 owner car. very clean and tight but the second gear syncro is gone, you can allmost shift up but not down. my question is are these trannys easy to rebuild or should i just buy a used unit and stuff it in.
i should mention that i have mechanical experiance 20 years and am not affraid to dive in and fix what needs done. im pretty sure im buying this car as its just a clean example and is what we are looking for. it will be a back up car for the 930 when its down for mods.
any help would be great.
cheers ed
akmtr is offline
Old 02-16-2009, 08:28 AM   #2
DrewP's Avatar
Ed,
It's not too hard, and if you have done transmission work before it won't be anything new.
The best thing to do would be to find a cheap copy of the Hanes manual for the 900, about the only good thing that manual has in it is a detailed teardown of the transmission with some good photos.
The factory Saab manuals have it too, and those pop up pretty often, but the Bentley manual does not cover tearing down the gearbox.
I think syncro assemblies are still available new from a few online parts houses like www.eeuroparts.com.
If you take it apart make sure that the shim stacks on the inner driver flanges go back on the correct side, it's how the lash on the ring gear on the diff is adjusted. If you don't take the output shaft our of the pinion bearing housing you won't have to go through the re-torque procedure for that, the pinion bearing housing just unbolts from the rear of the case.
You'll better be able to tell if it needs anything else while it's apart. It might be a good idea to replace the layshaft and coutershaft needle support bearing at the same time.
I think over on the SaabRally forum someone posted up the factory transmission manual so you can get the teardown procedure. I might have a PDF of mine too if you can't find it, let me know.
That being said, you can probably get a used one for under $200 from a salvage yard or another Saab person. So if you've got free time and enjoy doing it and want to tear into the Saab it's a good way to do it. Otherwise just replacing it would be how most people do it.
Keep in mind the whole engine has to come out to separate the trans, you can't just drop it out the bottom, so you'll need a hoist.
Best,
Drew
DrewP is offline
Old 02-16-2009, 09:04 AM   #3
Nate's Avatar
You could always double clutch. Not a permanent solution, but you could at least drive the car around.
Nate is offline
Old 02-16-2009, 10:03 AM   #4
DrewP
thanks for the response this is the info i was looking for, i may just to keep the car on the road just remove said engine and tranny and replace with good used unit. then rebuild the other maybe?
question is there a newer or better tranny that is a direct swap that would be stronger as i have read a little about the short commings of these trannys.
Nate
i can double clutch it for awhile but i really like things to be right. but it is a fun little car to drive.
ill do some research and see if i can find a tranny used around here.
cheers ed
akmtr is offline
Old 02-16-2009, 11:06 AM   #5
Jitters's Avatar
Originally Posted by akmtr View Post
DrewP
Nate
cheers ed
Hey Ed,
Welcome to the forum. Looks as though we are traveling down parallel paths. I've been working on my 900 SPG for the past several months as a backup to my 930 as well.
These are fun little cars and are a blast to drive when modded. I guess I've become addicted to the boost..
Since you're familiar with driving your 930, you should have no problems with your transmission in the Saab. I'm sure you're aware that you cannot rush a 915 or G50 box.
I've had no problems to date with mine. It's currently got $190K on the odometer and I drive the Saab just like I drive the 930. I pause between shifts, and I don't do burnouts and such. Not with the stock tranny. learned that the hard way when I first got my 930.
Good luck and welcome again.
Jitters
Life is a journey, enjoy the ride...
Jitters is offline
Old 02-16-2009, 11:29 AM   #6
Originally Posted by Jitters View Post
Hey Ed,
Jitters
thanks Jitters
i do know what you mean buy not rushing a 915 or G50, shifting these are all about finese and edicate. and the saab tranny has the same remote tranny feeling as a porsche.
the car im looking at has 140k on the clock and runs smooth and quite. its not rusty and is all original paint and most of the trim is hanging on fairly well.
is a turbo retro fit as easy as on a porsche? can i run low boost on standard compression N/A engine.
ok i need to stop i havent even got the car and im looking at modding it. its in my blood to tinker with all my cars. do you get over to PELICAN on the 930 section?
cheers ed
akmtr is offline
Old 02-16-2009, 11:54 AM   #7
c900 Grognard
Jack Straw's Avatar
It might be worth checking that the clutch is properly bled, and that the fluid is at an adequate level.
Originally Posted by IronJoe
Jack Straw is offline
Old 02-16-2009, 12:28 PM   #8
Jitters's Avatar
thanks Jitters
cheers ed
Hey Ed,
I'm pretty new to the Saab scene; however, I've come across quite a few posts regarding the N/A turbo upgrade. IIRC, you'd probably be better off doing a complete engine/tranny swap. From what I understand there are C/R issues that don't make the N/A engine a good candidate for the turbo upgrade.
There are additional parts that you would need to acquire as well, APC, ECU, Intercooler, etc.
I'm certain that when you have some time, you can search some of the previous posts to find more knowledgeable answers than what I offer.
Regarding the 930, I actually spend more time on Rennlist, 6Speedonline and PCARS, but I buy most of my parts from the Bird.
I've been following Guns 935 RSR mod for the past year and am in awe of the finished product...It one of the few that make me salivate whenever I see the car...
Again, welcome. There are a great group of guys here and they have been extremely helpful with providing help, opinions, and both solicited and unsolicited criticism.
Just gotta love'em....
You may also want to check out Saab Central as well. Most of the guys here also post over there as well.
Again, if I am doing anything against forum policy by mentioning other forums, please let me know.
Cheers,
Jitters
Jitters is offline
Old 02-16-2009, 12:29 PM   #9
thanks jack
now that i think about it even at a complete stop the im not sure that the clutch is totaly dissengaging as it still trys to grind and the tranny should not be spinning.
i have only driven this car about 5 miles and i still dont own it yet, but i called the guy today to finalize the deal.
as i found a tranny for for 200.00 locally so for around 1700.00 and some time i should have a nice little saab
cheers ed
akmtr is offline
Old 02-16-2009, 12:36 PM   #10
Jitters
i found a low milage turbo car with wreaked pass side for 600.00 running has tranny issues. the car is a 92 not sure if this is a good year swap . but i will do some research and see what i come up with.
cheers ed
akmtr is offline
Old 02-16-2009, 12:40 PM   #11
Jitters's Avatar
Jitters
cheers ed
Good luck Ed,
Don't forget to post some pics...
Jitters
Jitters is offline
Old 02-17-2009, 08:39 AM   #12
hey jitters here is the car i am looking at.
http://anchorage.craigslist.org/cto/1029995461.html
cheers ed
akmtr is offline
Old 02-17-2009, 08:51 AM   #13
Area6's Avatar
Nice car!
as far as swapping a newer tranny don't know if you would be able to get a much newer/stronger one in.
Then again anythings possible with money*
Area6 is offline
Old 02-18-2009, 10:08 AM   #14
Wagon Shaggin'
Saabeh's Avatar
Try swapping fluid as a quick last resort.
Saabeh is offline
Old 02-18-2009, 12:32 PM   #15
Jitters's Avatar
cheers ed
Hey Ed,
Well, it looks pretty good from the outside. If the inside is in decent shape and there are no rust issues, it looks like a pretty good deal.
I especially love the roof rack. I'd like to find one for my little buggy...
Good luck...
Jitters
Jitters is offline
Old 04-03-2009, 10:55 PM   #16
well guys it happened
i found my 900 its a 1991 turbo s 3dr, its a silver blue color with blue leather, we are the 3rd owners and it is truley a rust free car from colorado. it has 153k miles pops out of reverse if you dont hold onto it. and the front bumper end caps are missing. other than that what a fun little car. i hope to learn abit here and fix a few quirks and enjoy.
the turbo makes quite abit of improvment over the normals.
cheers ed
akmtr is offline
