Random Unplugged Connectors - The Saab Link Forums
Old 10-29-2017, 08:47 AM   #1
Exclamation Random Unplugged Connectors
I have a 1988 Saab 900 2.0 SOHC N/A that I picked up non-running for $700. While trying to diagnose the problem, I noticed a couple lonely connectors in the engine bay. One appears to be two one-wire female connectors just next to the block under the exhaust manifold. The other is, as best described a half-oval connector with a clip tab and two round female sockets, it looks like it comes out of the main harness which is close to the starter. If i remember correctly, one of the colors on the half-oval was orange. Might post a picture of them later if I get the chance. Would these possibly keep the car from running?
MadRomeo is offline
Old 10-29-2017, 10:40 AM   #2
Saab will have few connectors just sitting like that for no reason. You got K-Jetronic saab, those can be a problem getting running again
Raul is offline
Old 10-30-2017, 07:12 AM   #3
Picture would definitely help. I had that engine many years ago but my memory is hazy. Thing was bulletproof for me though! Hope you can get her lit!
BuHuSPG is offline
Old 10-31-2017, 07:14 AM   #4
I know there are some problems with the ECUs on these not grounding the FPR during cranking. Thinking this might be the problem. Taking pics of the connectors today and jumping 27 and 30 in the fb.
MadRomeo is offline
Old 10-31-2017, 07:15 AM   #5
Really hoping the fuel pump just went out on it, posting connector pics later.
MadRomeo is offline
Old 10-31-2017, 09:52 AM   #6
can you hear the pump start priming when you turn the key to the ON position? flip the rear seat up to make it easy to hear. If you can hear it run for a few seconds before starting the car then it is working and you have another issue
BuHuSPG is offline
Old 10-31-2017, 02:58 PM   #7
A little hard to hear over the power antenna, but had a friend take a closer listen and nothing...
MadRomeo is offline
Old 11-01-2017, 03:49 AM   #8
that's probably your issue, I would start there. You should hear it prime. Make sure it is getting power first when you turn key on before you buy a new one.
I don't recognize those connectors off the top of my head.
BuHuSPG is offline
Old 11-01-2017, 06:49 AM   #9
I had this problem on the same year/engine. It would start and run with the fuel pump jumpered.
This. Jumpering the FP in the fusebox will confirm power at the pump.
I'm guessing those connectors are not related to your issue.
'93 900T Comm.Ed#119
'83 900T 5M 4dr
'87 900S 5M Notch
'88 900S 5M 4dr
'91 & '93 900S 5M 3dr
Parted/scrapped: '82 4dr, '85 3dr,
'86 2dr, '86 3dr, '87 4dr, '90 T3dr.
jimbosaab is offline
Old 11-01-2017, 08:54 AM   #10
DrewP's Avatar
The only place that I can recall those two contact grey 'oval' connectors on the C900 is for the radiator fan. Does your car have one radiator fan, or two?
Does your engine have the starter motor under the exhaust manifold, or under the intake manifold? On earlier cars with K-Jet with the starter under the exhaust manifold, there were additional terminals on the starter that run the fuel pump while the engine starter is cranking. It's possible it's a leftover from that.
Do you have a Bentley manual with the wiring diagram?
DrewP is offline
Old 11-02-2017, 09:25 AM   #11
I believe it has two, but I see what you are saying. The passenger side fan does have a connector that looks very similar, but looks to be a little bigger...
As for the starter, it is under the intake. Would the remnant connectors be causing my fuel pump problems? Or did they bypass that for the later jetronic cars? I do not have a manual but would be very interested in obtaining one. I bet it would help a lot.
MadRomeo is offline
Old 11-02-2017, 09:27 AM   #12
I did not hear the pump, even when close to it.
MadRomeo is offline
Old 11-02-2017, 09:28 AM   #13
I guess since I'm not hearing it, the best solution would be a fuel pump? I know the paper clip I used is jumpering them because the insulation on it started to come off from the heat.
MadRomeo is offline
Old 11-02-2017, 10:48 AM   #14
It sounds like it, assuming you are jumping the right things.
BuHuSPG is offline
Old 11-02-2017, 10:57 AM   #15
I jumpered the terminal closest to the fender on 27 and the terminal closest to the engine bay on 30.
MadRomeo is offline
Old 11-02-2017, 01:44 PM   #16
Check for 12V at the pump when you've got it jumpered. If there's no power, the pump might not be bad.
Old 11-02-2017, 03:33 PM   #17
[QUOTE=jimbosaab;2182689]Check for 12V at the pump when you've got it jumpered. If there's no power, the pump might not be
Am I correct thinking I can access it under the backseat?
MadRomeo is offline
Old 11-03-2017, 04:29 AM   #18
Access to the top of the fuel tank is under the floor in the hatch/trunk. Fuel pump is left of center (the larger round plate) and fuel level unit to the right.
Old 11-04-2017, 12:41 PM   #19
Much appreciated
MadRomeo is offline
Old 11-04-2017, 12:43 PM   #20
So I guess the connectors simply don't go anywhere?
MadRomeo is offline
Tags
900, connectors, electrical, raul make diagnose, saab, wiring, y u no help raul
