excessive vibration 2004 9-5 2.3t wagon - The Saab Link Forums
Old 12-22-2014, 01:52 AM   #1
Cool excessive vibration 2004 9-5 2.3t wagon
Recently bought 2004 9-5 Wagon 2.3t; excessive vibration at idle and more so in gear with brake on. any thoughts on cause/fix? (service/dealer mentioned car having short belt in lieu of long belt).
Newsaabi is offline
Old 12-22-2014, 03:26 AM   #2
Your motor mounts are worn out. Not too expensive and not that hard to replace.
Mike Brennan is offline
Old 12-23-2014, 07:11 PM   #3
Dealer still says problem is having a short serpentine belt vs long belt. Says that Saab did this to save money - doesn't make complete sense to me. They say mounts are all okay. I recently had transmission mount replaced (it was bad) but had no effect on vibration. Guess I can pay for new long belt (idler arm to accommodate long belt is installed) and see what happens.
Newsaabi is offline
Old 12-24-2014, 05:26 AM   #4
That sounds pretty bogus to me.
Usually when one motor mount gets really bad, it puts undo stress on the other ones, and they fail soon after. On transverse engine mounted, front wheel drive cars, transmission mounts are the same as engine mounts.
A bad misfire or running condition would cause similar vibration or shake, but you would probably have a check engine light to show for it.
The belt alone is not a viable answer. Has the car always vibrated with this belt on?
BuHuSPG is offline
Old 12-24-2014, 06:56 AM   #5
Drew in Houston's Avatar
Has the dealer plugged into the car to verify anything yet? First thing I'd check is vacuum at idle. What rpm is it idling at? Is it missing? I'd do good a visual once over on all hoses/connections and look for breaks
Drew in Houston is offline
Tags
vibration
