Oh No! My 9-5 Went Swimming! :o - The Saab Link Forums
Old 11-10-2014, 04:26 PM   #1
I've owned my 2003 9-5 Aero Wagon MT for about 3 weeks now and it may be the end of it! A week ago we had some major rain thanks to the 3 hurricanes that just missed the islands. Long story short I was driving in heavy rain and ran into a puddle. Engine sucked up the water and stalled. I parked the car in a local park about 40 miles away from my house.. Went back a few days later got all the water out of the intake and ic/piping etc.. i pulled the plugs and turned it over.. it shot loads of water out.. I had hope all seemed to be going well.. I figured if it started i would take it to a shop and have them flush the engine. I got new plugs.. They weren't the same as the ones that were in it.. The guy at O'reilys looked at me like i was the dumbest person in the world when i tried to explain that they had to be the specific plugs (saw that on forums). I took the plugs over to the car and installed.. When i turned over the ignition it cracked about 5-6 times and then made a loud bang noise and then cranked 1-2 times more.. As soon as i heard that bang I stopped trying to start it.. Weird thing is it didn't happen when the plugs were our and i turned it over.. I do remember that i forgot to take the fuel pump fuse out before cranking it the first time so i most likely flooded it with fuel. I had to leave but I will be going back to get it towed home and then inspect further. Hopefully there isn't damage.
oscxj220 is offline
Old 11-11-2014, 04:21 AM   #2
Drew in Houston's Avatar
Good luck. You should borrow/buy a compression tester before buying any new parts, that will tell you if there's major damage. Checking compression is no harder than changing spark plugs.
Drew in Houston is offline
Old 11-11-2014, 04:43 AM   #3
jssaab's Avatar
You have suffered a condition known as hydro-lock, it has probably destroyed your engine.
Buy a new engine...
jssaab is offline
Old 11-12-2014, 01:47 AM   #4
If you did hydro lock your motor do not tell your insuror that you tried to start it. Tell them you heard the bang is you went thru the water. You motor will be covered by your comprehensive.
Mike Brennan is offline
Old 11-12-2014, 05:41 AM   #5
Wagon Shaggin'
Saabeh's Avatar
My friend hydrolocked his 9-5 with 200k. If you cleared all the water and didnt damage the motor, it should run. I bet that attempted start still had water in places. Trick is to use a shop vac to pump water out.
Saabeh is offline
Old 11-12-2014, 11:06 AM   #6
Buy a new engine...
My engine isn't hydro-locked if it turns over right? My problem is potential damage from when it was hydro-locked.
I made an insurance claim.. After taking their sweet time to actually come and look at the car. The adjuster seems to think the car is fine and just needs to sit and dry out lol.. I don't think he knows much about hydro-locking an engine.
oscxj220 is offline
Old 11-14-2014, 11:46 AM   #7
nowhereman's Avatar
he doesnt need to anything about hydro-locking an engine.
have the car towed to a reliable mechanic and have them diagnose the problem in writting and submit that to your insurance company. they will have to replace the motor if it is covered. they arent a mechanic and cant really argue with one.
and DO NOT tell them you tried to fix yourself or start the engine. that will likely void your claim.
tell them it died driving through the puddle. or shortly after when the BANG occured
2008 9-3 SS: Stg 1
nowhereman is offline
