Key not accepeted - The Saab Link Forums
Old 08-30-2014, 08:53 PM   #1
Key not accepeted
Hi, would anyone be able to give me advice on my problem?
Got into my car yesterday morning after a long shift at work wich is 200 kilometers from home and noticed when I unlocked the car that only the drivers door unlocked, I unlock it with the blade key because the key remote has never had batteries in it in the time ive owned the car.
next thing I put the key in the ignition and the car didn't start, all the reds came on but no start so I assumed I left something on and flattened the battery so I grabbed the booster pack out of the truck and tried to jump start it and it still did the same, then I noticed on the SID "KEY NOT ACCEPTED"
I am now back home and the car is 200 kms away,
Here is what I observed.
Passenger seat not moving but drivers seat still works.
central locking not working.
Steering lock stays unlocked.
with new battery in the key remote there is still no remote (although I have never had the remote working in the time I owned the car)
A relay under the passenger side seat is clicking several times after I try to start the car.
sometimes the starter motor clicks when I turn to start.
With the ignition on, and a jumper wire to the starter I can turn the engine over but the ignition or fuel system seems to not be working.
the coil around the ignition switch under the rubber cover is all intact, unbroken and soldered in at both ends.
radio, cig lighter, wipers etc work with the key on.
All fuses related to starter, ignition, fuel pump, twice dice etc are good.
both keys do not work!
Leon J is offline
Old 09-08-2014, 04:05 PM   #2
Check the Twice unit under the drivers seat to see if it's wet..
gbest is offline
Old 09-08-2014, 07:38 PM   #3
what year is your car?
Snowcat77 is offline
Old 09-21-2014, 07:46 AM   #4
Twice is the problem.
My 2000 95 SE Wagon has the same problem. The Twice unit under the drivers seat IS wet. At first the sid did say: key not excepted, but now it does not. The power door locks do not work. The sid now says : check OK. I had a Saab mec check out the codes and everything is ok but the Twice. The code says: twice not responding. The engine does turn over but it won't start. I'm told I need to take out the twice and dry it out. If that don't work. Buy a used one on ebay along with the key and ignition cylinder. There about $200.00. My Saab is just sitting in the driveway. It only has 85000 on it. I just did the timing belt, water pump, bypass valve, mufflers, front wheel bearings. I'm told the reason the Twice got wet, is because one of the drains for the AC is clogged on one side and the water comes in the car on the floor. Hope this helps.
chazmatic is offline
Old 09-21-2014, 02:50 PM   #5
Do you have an all in one key?
If so, you don't need the ignition cylinder, just the Twice and an all in one transponder, you will need someone with Tech2 to program the new Twice to the cars ECU.
I have a Twice/all in one transponder available if you need one.
Where are you located?
gbest is offline
