Mechanic says new engine - The Saab Link Forums
Old 08-13-2014, 07:15 AM   #1
Our 95 has 150K miles. Serviced regularly by our local Saab mechanic.
Recently oil light coming on at idle.
He changed the sender, cleaned sludge and is still getting significant pressure drops.
His recommendation is new engine.
We need to know should we get a second opinion or just move on to a new car. This car has been largely unreliable. New turbo last Sept. DI cassette, etc etc.
I should say, we don't really WANT a new car or car payment and were hoping this one would go to 200K and 20 years. Should we invest more in this car or move on? Our mechanic doesn't even recommend putting any more $ into it.
Thanks for your help!
dcsw is offline
Old 08-13-2014, 07:21 AM   #2
150k is not chump change, you likely got your money worth out of the car.
You are looking at real money even if you secure a 70k mile engine from a dismantler, you are still looking at $2000-3500 installed which is worth more than the car.
Jameson is offline
Old 08-13-2014, 07:35 AM   #3
Which year and model 9-5?
Sludge probably killed the turbo, so your local Saab mechanic should have dropped the oil pan THEN. (Was that recommended at the time?)
Is it smoking heavily or making noise?
Old 08-13-2014, 08:05 AM   #4
Since earlier 9-5s (99-03) were prone to sludge/oil pressure problems, used 9-5 engines are a crap shoot IMO. You MAY end up with an engine that's not in much better condition than what you've got
As stated above, year and model would help us give you better advice
seriks1 is offline
Old 08-13-2014, 03:24 PM   #5
150k is pretty good for a poorly maintained 9-5 with sludge issues. One I had only got to 125k miles before it punched a rod through the engine block.
As mentioned, 99-03 9-5's are sludge prone. If the owner followed saabs reccomended schedule the engine won't last long. On the other hand if they brought it in for service and the dealer was any good it should have received the necessary updates to keep it healthy.
My 00 aero is proof that 3-5k oil changes with quality synthetic is what these cars really need. Unfortunately saab did not spec syn oil in 9-5's that were not aeros.
My advise, move on unless you have skills to do the work yourself. If you act now, there is a good chance you can rebuild the current motor with your same parts ( block pistons etc). If you keep going it will get worse. On the other hand, you could try your best to clean it out and nurse it along and it might surprise you. I wouldn't drive it cross country though!
Tboy is offline
Old 08-13-2014, 04:31 PM   #6
oliversexpedition's Avatar
any signs of headgasket leak? Is it an Aero? What part of the country, maybe someone can help?
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 08-15-2014, 05:38 AM   #7
I'll buck the trend here.
If the engine otherwise runs well and quiet, I'd certainly pull the oil pan and front pulley and install a new set of main and rod bearings and an oil pump.
It'd take an afternoon under the car and not a whole lot of money.
win_k is offline
Old 08-15-2014, 08:37 AM   #8
Bingo. If there's no noise or excessive smoke, then it would be worth it to fix...
Old 08-15-2014, 11:52 AM   #9
Wagon Shaggin'
Saabeh's Avatar
^ agreed
Saabeh is offline
Tags
new engine, oil pressure light
