Car Problems? 9-5 Only If you're experiencing problems with your 9-5, post your question in here. CEL Code or GTFO! |
LinkBack | Thread Tools |
#1 |
Solar charging via cigarette lighter socket
Hi folks
I don't use my 2001 Vector much and the battery goes flat (probably down to the alarm etc.). I bought a solar maintenance charger that is supposed to trickle charge via the socket but doesn't. It's been tested and works fine. Any clues? Ken |
Sponsored Links | |||
#2 |
Does the socket have power when the key's off? If you want to use that socket to back feed power to the battery it has to be active when the key's removed and the car's off.
Co-Founder: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. First T7 19T turbo setup. First T7 Deka 80lb. injector setup. |
#3 |
Ah! A quick check and you have hit the nail on the head. Many thanks.
Now - how to get round the issue, tidily? I could run a separate lead into the glovebox perhaps.... |
#4 |
That could work. You just have to watch the amperage of the fuse and overall circuit. Alternatively, you could run a new independent feed direct from the battery (with it's own fuse)
#5 | |
you may also want to find the problem that is causing the battery drain to begin with.
2008 9-3 SS: Stg 1 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , GS Strut Bar, GS 3 Point Chasis Brace, K&N Filter, Ebay Trunk Lip |
#6 |
Your car was built with dirty hippie protection. Won't allow charging unless the donor is using fossil fuels or baby seal oil as its source.
-adam |
Sponsored Links | |
Thread Tools | |
