Driver seat moving by itself - The Saab Link Forums
Old 06-15-2014, 03:32 PM   #1
My driver seat is moving all by itself. Forward, back and tilting.
I had to unplug the box under the seat for it to stop. Any ideas??
newsaabguy is offline
Old 06-15-2014, 03:51 PM   #2
Probably the switch pack, possibly the little controller underneath. This happened on my past 9-5, cause my wife left the window down and it rained. Went to the junkyard to get both and replaced them at the same time, used ones should be cheap to replace both.
Tboy is offline
Old 06-16-2014, 02:17 AM   #3
I don't think this car has gotten wet, but certainly worth looking into the switch pack. When we got the car a year or so back , the seat moved normally. Then maybe 6 months ago, it started moving like 1 inch at a time in bursts, not a smooth slide or tilt, everything was in little bumps. Now its going all by itself. Opened door yesterday to find seat going front to back, and the seat bottom tilting up, all by itself. I moved all the seat buttons, and could get it to go the direction I wanted, but soon as I let go it kept heading the way it wanted to. So I unplugged the box under the seat so I could drive it.
Old 06-16-2014, 08:23 AM   #4
DrewP's Avatar
See if one of the memory buttons is stuck down, or unplug just the memory buttons and see if it stops.
DrewP is offline
Old 06-16-2014, 12:01 PM   #5
Good idea, I didn't touch those. I only messed with the buttons that move the seat. I will give it a try. Will the seat work if I unplug the memory buttons? I don't need the memory function. But would be nice if the seat moved only when I tell it too.
Old 06-16-2014, 01:08 PM   #6
Seat will move normally without the memory switch.
seriks1 is offline
Old 06-16-2014, 04:43 PM   #7
Ninety5Aero's Avatar
Did the switch get wet?
Ray
2000 Viggen 'vert
2000 9-5 Aero
1998 9000 CSE Turbo
1994 9000 Aero
Ninety5Aero is offline
Old 06-16-2014, 06:58 PM   #8
After my wife left the window down, the seat memory no longer worked and it moved in spurts as well. It wasn't till several years later it decided to move on its own.
Tboy is offline
Old 06-17-2014, 02:07 AM   #9
NickTurbo900's Avatar
Spilled coffee or drinks on the memory switch pack is a common cause of this. You can take apart the memory switch and clean it. If the seat only moves in jerking motions, not smooth, one of the memory buttons is down.
NickTurbo900 is offline
Old 06-17-2014, 04:42 AM   #10
This used to happen on my old 9-3.
It was the switch-pack.
it was in conjunction with a bad position sensor that caused the seat to only move in 1" incriments.
We had to just set the seat, and pull the fuse.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 06-24-2014, 01:26 PM   #11
my daughter reminded me that when we got the car the window track was messed up and the first few days we had it the window was half shut and it rained overnight. Forgot all about it until she said something about it. It was a couple months later the seat moves in increments of an inch or so. Now it just does what it wants to. I haven't had time to fool with it. I will unhook the memory buttons and see if it will at least function so we can move the seat as needed. Thanks for all of your help with this. Sounds like you have hit the nail on the head!
Old 06-28-2014, 04:23 PM   #12
UPDATE: I unplugged the memory switch and the seat works perfectly. It moves smooth now, not in 1 inch increments.
Thanks for everyone's input! Who would've thought this could be so simple!
