P0137 - '07 Aero - The Saab Link Forums
Old 04-24-2014, 01:54 PM   #1
nocluetim's Avatar
P0137 - '07 Aero
I've posted this on the other board but haven't been able to figure it out yet. Code is stating the second O2 sensor has low voltage. I've replaced the sensor with a Bosch #16175 from eeuroparts and installed a new battery. I've also checked the plug. I will start the car, reading is about .5 volts then tapers off to 0. If I unplug the sensor all together I get .5 volts steady. Plug it back in, bang 0 again. Getting frustrated.
'95 900se, '07 9-5 Aero
nocluetim is offline
Old 04-25-2014, 11:17 AM   #2
Some sensors use the exhaust as a ground and as such, need a ground strap.
If it's broken, you get super wonky readings.
I'd look for that. There's usually a ground strap or bracket on the downpipe between the sensors, or very close to them.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 05-07-2014, 06:14 AM   #3
nocluetim's Avatar
There's a mounting bracket that connects the exhaust to the engine. I checked it, nice and tight. I also went through the O2 wiring diagnostics in the WIS. Wiring checks out. Could these type of readings indicate my cat is bad?
Old 05-14-2014, 06:08 AM   #4
nocluetim's Avatar
This fixed it.
Old 05-14-2014, 06:48 AM   #5
so.. bad Cat?
heck of a reason to go 3"
Craig R.
g96nt is offline
Old 05-14-2014, 07:40 AM   #6
nocluetim's Avatar
Yes, I believe it was a combination of a bad cat and a crappy bung extension someone welded on to repair stripped threads. It moved the sensor about 2 inches away from the flow.
"If you have the means, I highly recommend picking one up." -Ferris Bueller
Old 05-14-2014, 09:26 AM   #7
nocluetim's Avatar
Here's the bung I mentioned.
Old 05-14-2014, 11:40 AM   #8
DrewP's Avatar
Pffff.... yes. That's your problem.
Glad you found a nice 3" workaround!
DrewP is offline
