99 95 heat not blowing - The Saab Link Forums
Old 03-13-2014, 07:24 PM   #1
Kevin dangas's Avatar
So trying to help out a friend it's a 99 95 So The blower motor is not working currently. But before the motor stopped. It was blowing cold on the driverside and hot on pass when both sides were on full heatan the heat was working on the pass side but not the drivers an did the acc codes an it said the drivers side blend door then not to long after that the heat stopes on the pass now it's just cold air all around is it the blower motor that's seized Or a fuse or the resister any thought or am I just going to have to tinker around or is this a common problem ? Thanks
Kevin dangas is offline
Old 03-14-2014, 05:13 AM   #2
I see you know about the blend door. That is a start. If you blower is not turning you will have to remove it, 04.02.2006: Saab 9-5 Blower Motor Repair - photo.platonoff.com
Once you have removed it very often it just the brushes that you can buy anywhere that sells stuff like that. Solder in new brushes and see if it powers up. Not the best job in cold weather but if it not the brushes a used blower is not too bad.
Here is the link to the brush replacement procedure.
BLOWER MOTOR EASY FIX... CABIN FAN SERVICE CONTROLLER Replacement - SaabCentral Forums
Mike Brennan is offline
Old 03-14-2014, 07:54 AM   #3
Blower motor is it the same part for the 93 an 95
Could I use a blower motor out of a 2001 93 an put it in a 1999 95 or are they different
Old 03-14-2014, 09:19 AM   #4
they're different.
help me understand better, here; is it blowing, but not blowing hot air?
Or, is it not blowing at all?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 03-14-2014, 12:22 PM   #5
Yah I guess it was only blowing on pass side an then just went out shortly after I think my friend said it may be seized an the blend door is snapped on the drivers side always one thing after another lol
