Ticking starting at about 2k rpm - The Saab Link Forums
Old 11-15-2013, 07:14 AM   #1
Marks9-3's Avatar
'02 9-5 Aero that had a bad head. Sounded like a failed valve. Replaced the head with a known good one. Ran the car and now there's a tick starting about 2k rpm. Sounded like it was coming from the injectors. Replaced those with known good ones.
2k+ rpm tick is still there. Did the wood dowel test on the valve cover to be sure the sound wasn't coming from the intake valves. Still sounds like it's coming from the injectors.
Would a bad seal or an injector not seated right cause this? It's loud enough you can hear it in the cabin so I'm thinking not. Never experienced this before so I'm at a loss.
Marks9-3 is offline
Old 11-15-2013, 07:22 AM   #2
Send a message via AIM to tapper
Get a mechanic stethoscope and prod around everywhere til u find where its loudest... don't forget the block...sound travels and is tricky.
tapper is offline
Old 11-15-2013, 12:03 PM   #3
Legit's Avatar
Could be a worn oil pump / housing. Only thing is you have to pull the head to get at the housing.
2002 Viggen Convertible
Legit is offline
Old 11-15-2013, 06:37 PM   #4
93viggen's Avatar
Did you use the lifters from the bad head..?
Using waste to make haste!
93viggen is offline
Old 11-16-2013, 04:32 AM   #5
Marks9-3's Avatar
The entire head came over as a unit. The car the head came off with was drivable with no noise.
The more I think about it the more I'm inclined to say it's early rod knock.
Marks9-3 is offline
Old 11-16-2013, 08:40 PM   #6
Want to post a vid of the sound? It never seems like rod knock can be confused with any top end ticking, but without hearing it, it is tough to tell.
Rod knock is just so much more violent sounding...
BuHuSPG is offline
Old 11-16-2013, 08:43 PM   #7
And your sure you have good oil pressure? You know all the traditional worries with sludge, oil pressure relief valves and such...
Your sounds starts at 2K and continues up through the RPMs? I doubt you've revved the piss out of it, but does the sounds progress up, or does it stop at a point?
BuHuSPG is offline
Old 11-16-2013, 08:57 PM   #8
Marks9-3's Avatar
I can get a video soon.
The sound becomes noticeable about 1.5k rpm and goes up. Haven't taken it over 3k to see it continues. Oil pressure was good up by the sender on the back of the block. I bought a mechanical gauge a while back.
It's deffinantly a little more than a tick. I'll post a video sometime soon. Late nights/early mornings for work cause little time to work with the car.
Marks9-3 is offline
Old 11-16-2013, 08:58 PM   #9
I hear ya man. Good luck.
BuHuSPG is offline
Old 12-02-2013, 05:40 PM   #10
Marks9-3's Avatar
I'll post some pictures soon, but the #3 rod bearing is totally shot. Surprised it didn't spin. #2 was in ok condition. Cylinder walls look good and the crank only shows a tiny score on the #3 position. Going to measure it and see if I can get it away without having to have it turned.
Hoping to get away with just new rod bearings and piston rings and not having to drop the motor.
Marks9-3 is offline
Old 12-02-2013, 06:28 PM   #11
oliversexpedition's Avatar
Check the mains, have a 9-5 engine at the mechanist with spun rod and main bearings.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 12-02-2013, 06:28 PM   #12
Wagon Shaggin'
Saabeh's Avatar
How many miles were on the bottom end?
Saabeh is offline
Old 12-02-2013, 06:35 PM   #13
Marks9-3's Avatar
I did the work with the motor in the car. All I'll be able to check are the bottoms of the middle ones. Planning on it to at least have an idea.
138k. But unknown service history prior to about 125k miles.
Marks9-3 is offline
Old 12-03-2013, 07:19 AM   #14
Marks9-3's Avatar
Here is the #3 rod bearing. Caught it just in time for sure with nothing but copper showing.
Marks9-3 is offline
Old 12-11-2013, 11:20 AM   #15
Marks9-3's Avatar
Got the goods to put it back together including the updated air intake thing from the '04+.
Piston Rings
Rod Bearings
Gaskets
Vacuum Hose
Head Bolts
Misc O-Rings
Marks9-3 is offline
Old 12-11-2013, 05:44 PM   #16
jssaab's Avatar
Did you check the mains???
jssaab is offline
Old 12-12-2013, 07:31 AM   #17
Marks9-3's Avatar
Only the bottom of the middles ones, engine is still in the car. They were all fine.
Marks9-3 is offline
