Fuel Pump time? - The Saab Link Forums
Old 08-28-2013, 06:31 AM   #1
Fuel Pump time?
92,000 miles. Seems to be hitting a wall at 4500 rpms. Also seems that the "aftermarket" pump assemblys are all on back order via the usual suspects.
Anybody have any input?
My plan is to Car-part an assembly and install a 255 and swap that in. 06 and up cars have a diff pump assembly, intank filter, and no floor hole. Fun times.
Old 08-28-2013, 06:33 AM   #2
Wagon Shaggin'
Saabeh's Avatar
I always thought that they just up and died, they didn't slowly deliver less fuel.
Saabeh is offline
Old 08-28-2013, 07:14 AM   #3
Sometimes the first sign is an inability to deliver fuel at higher RPMs, leading to the boost cut. From then on, it's just a matter of time...
But 92K miles is still a bit young for a fuel pump...maybe a bad wastegate actuator?
Old 08-28-2013, 11:58 AM   #4
Harvey's Autohaus's Avatar
Even if you use a Used "bucket" with a new fuel pump inside. We are still going to install a new fuel level sender as well. The sender is the same part that comes in the sport sedan, The assembly is different but the sender is the same part, Cheap & fails on a regular basis. Hopefully that will save pulling the tank twice.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 08-29-2013, 05:31 AM   #5
Ochy38's Avatar
I can't speak for the saabs, but I did have an '89 Chevy Celebrity where the original fuel pump stopped putting out the right pressure randomly and the car would start driving like it was missing 2 of the 6 spark plugs. Played with the throttle enough and it would eventually start running well again. I drove it like that for 4 months and swapped ignition coils, plugs, wires, and the ECU until I was finally able to figure out what the problem was.
Ochy38 is offline
Old 08-29-2013, 07:09 AM   #6
Good to know, I just ordered the evap hose it needed, a walbro 255, and a junkyard assembly for $65. Will add on the sender too if you don't have one.
Old 08-29-2013, 07:20 AM   #7
rarelibra's Avatar
Send a message via Yahoo to rarelibra Send a message via Skype™ to rarelibra
Ben - I have a fuel assembly for a 9-5... you need it?
i don't think a c900 has sold for 28k since the day one left the dealership new.
rarelibra is offline
Old 08-29-2013, 05:47 PM   #8
Ben's Car is more similar to a sports sedan fuel system vs, A nice early servicable 'up to 05" saab design. Around 06 or 07 somewhere the tank & fuel pump changed to the later style.
HakbarSAABzzz
