Fault Code Help - The Saab Link Forums
Old 06-13-2011, 03:40 AM   #1
Fault Code Help
My 2001, 9-5 has engine code P1312. I've changed spark plugs. Anything else I should check before replacing the expensive Direct Ignition Module? Any help is appreciated.
green95 is offline
Old 06-13-2011, 03:52 AM   #2
BurnsSide42's Avatar
Welcome!
What plugs did you use? You can ONLY use the OEM specified NGK plugs - otherwise you will get CEL and could possibly damage your Ignition Cassette.
Did you check gap on the plugs as well?
Check out
for your repair needs
BurnsSide42 is offline
Old 06-13-2011, 04:07 AM   #3
CEL came on first. Replaced with NGK's gapped at .040". Also pulled casette connector and reseated. Any other ideas?
green95 is offline
Old 06-13-2011, 04:08 AM   #4
Also forgot to note, that after plug replacement, cleared codes, and it came back.
green95 is offline
Old 07-09-2011, 02:03 PM   #5
Galvas's Avatar
P1312 - Ignition coil - knock detection cil 1 & 2 ( open circuit/short to positive/ignition coil assembly
New DI
Galvas is offline
