Freaky problems today in the 9-5 Aero.... - The Saab Link Forums
Old 10-05-2010, 08:22 PM   #1
Talladega900's Avatar
So here's one I've never encountered before.
Had to run a couple of errands tonight. So we load up the twins and head out. We don't even get a half mile from the house when all the idiot lights light up, the instruments though go to zero (gas, speedometer, etc.), the center console -- ACC and radio controls -- light up to their brightest, radio turns on full blast with a loud "POP" scaring the crap out of the twins, and both headlights are blown. (Funnily enough though the 5-watt driving lights are fine.) It reminded me of a scene from "Close Encounters" where everything in the utility truck just turns on. LOL! No, no little green men, but one helluva green gremlin...
Engine-wise all is normal. Car never throws a code, and never goes into limp-home mode. Nevertheless, we turn around, park it, and take the 9-7X instead.
I'm having it flat-bedded to my local indie, S & S, for fear of either stranding me, or worse, another electrical surge killing electronics (frying the T7 perhaps?) -- there're what? ~13 microprocessors in the 9-5?
Anyhow, any ideas? I figure alternator going bad.
Jim Miller
'91 900 Turbo SE Convertible
'93 900 Turbo CE #116, modified
'02 9-5 Aero SportWagon, MT
'06 GTO, modified
'08 9-7X 6.0 Aero. The fastest stock Saab I've owned, bar none.
Talladega900 is offline
Old 10-05-2010, 08:27 PM   #2
spgproject's Avatar
wow. alt. definitly sounds like a possibility to me, but an odd failure at best!
hopefully marty or drew p will chime in, i've never seen anything like that.
xenon bulbs?
did everything work fine after that?
-Sir William Lyons
spgproject is offline
Old 10-05-2010, 08:44 PM   #3
Nope. Standard headlights.
Jim Miller
'06 GTO, modified
Old 10-05-2010, 08:50 PM   #4
Voltage regulator?
Sound freaky.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 10-05-2010, 09:00 PM   #5
Yeah, thinking along the lines of alternator/VR. We shall see.
T'was very bizzare. Wife was ready to pull the parachute and bail then and there...
Jim Miller
'06 GTO, modified
Old 10-05-2010, 10:06 PM   #6
AUPilot09's Avatar
Send a message via AIM to AUPilot09
Whoa. Very freaky. Doesn't sound engine related, no fuses popped anywhere?
AUPilot09 is offline
Old 10-06-2010, 04:17 AM   #7
BurnsSide42's Avatar
Originally Posted by PoisonBeef View Post
Voltage regulator?
Sound freaky.
That was my gut feeling reading this. Sounds very much like the VR on the alternator which has failed. Also could be a shorted battery - but this could be a result of a bad VR.
FYI - rebuilt Alt. are cheaper then the parts and labor to replace the VR on a 9-5 or 9-3 generation unit.
Check out
for your repair needs
BurnsSide42 is offline
Old 10-06-2010, 07:53 AM   #8
My BMW did that and it was a bad ECU...the car seats started moving back and forth, the radio turned off and on...all kinds of stuff
cking1975 is offline
Old 10-06-2010, 08:14 AM   #9
That's what happens when you do a k turn in the parking lot at langly, defense mapping, NRO, ect.
Old 10-06-2010, 08:48 AM   #10
IronJoe's Avatar
Christine.
IronJoe is offline
Old 10-06-2010, 08:53 AM   #11
Seriously.
The car sits for now. Rollback coming this afternoon.
Hmmm. Guess I'll have to submit a photo to the "Saabs being towed" thread....
Jim Miller
'06 GTO, modified
Old 10-06-2010, 01:32 PM   #12
Verdict is in:
as we all suspected, alternator. While it's in, I'm having the AC looked at (recall my post on the driver's zone not cooling....).
Towed at 2:30, callback by 4. Should have it back tomorrow. Sometimes it's just easier having someone do it than DIY...
Jim Miller
'06 GTO, modified
Old 10-06-2010, 02:15 PM   #13
jssaab's Avatar
Originally Posted by Talladega900 View Post
Verdict is in:
Where do you get it serviced? Looking for a place near DC I think you said Viking in Gaithersburg is good is that right?
jssaab is offline
Old 10-06-2010, 02:33 PM   #14
Viking is fantastic. Eric Heyse is good people, but a bit far for me. Since I live 50 miles west of DC, getting to Gaithersburg can be a challenge.
S&S is within 15 minutes of me in New Baltimore, Va. (South of Gainesville, north of Warrenton on Rt. 29), have loaners if I need them, and their own towing. Not a bad set up.
Jim Miller
'06 GTO, modified
Old 10-06-2010, 02:58 PM   #15
Rude sears by Viking too, he also keeps an eye on thier lot at night. I have yet to try them.
There is also Harvey's Auto in Finksburg MD. I haven't made it up there but he lent me his caliper tool last month.
Old 10-07-2010, 07:55 AM   #16
jssaab's Avatar
thanks guys the 86 C900 needs some loving for winter and I have some issues with the 9-5 that I need to get a TechII read on ( once I get it back together again), I will take it by Viking Next week if the guys at Gerneal sales back in PA don;t have time tomorrow or Sat.
jssaab is offline
