Saab Tech: How to retrieve fault codes for ACC - The Saab Link Forums
Closed Thread
Old 09-05-2010, 10:51 AM   #1
BurnsSide42's Avatar
Post Saab Tech: How to retrieve fault codes for ACC
How to retrieve fault codes:
If you wish to view the fault codes your ACC unit has stored, simply hold down the AUTO and OFF buttons on the ACC control panel.
The display will then display a single digit number on the left, and a double digit on the right.
i.e 1 ____ 21
This would signify 1 fault code stored, code 21
Fault Code
Defective function/component
Malfunction
Tech2 Code
1
Control module
Internal control module malfunction
B1605
2
Cabin temperature sensor
Open circuit or short to B+
B1350
2
Short-circuit to ground
B1350
3
Solar sensor
Open circuit or communication error
B1340
4
Mixed-air temperature sensor, LH
B1345
4
B1345
5
Mixed-air temperature sensor, RH
B2345
5
B2345
6
Stepping motor, air-mixing flap, LH
Open circuit, short to B+ or short to ground
B2490
7
Jammed flap
B2496
8
Stepping motor, air-mixing flap, RH
Loose flap
B2295
8
Loose flap
B2495
9
Open circuit
B2290
9
B2290
10
Jammed flap
B2296
12
Stepping motor, air distribution flap
Open circuit
B2400
12
B2400
13
Jammed flap
B2406
14
Loose flap
B2405
18
Heat exchanger solenoid
Open circuit, short-circuit to ground
B2375
18
Short-circuit to B+
B2375
19
Circulation pump
B2380
19
Circulation pump
Short-circuit to B+
B2380
20
Control voltage, fan
Short-circuit to B+
B2425
20
B2425
21 Direct current motor, air recirculation flap B+ open circuit or shorted to ground B2410
22 This fault code means the ACC software is corrupt, this will require reflashing by a dealer using tech2
Most ACC systems will work normally with this code.
23
Sensor ground
Ground to sensors shorting to B+
B2945
Information provided by: www.saab9-5.com
BurnsSide42 is offline
Quick reply to this message
Closed Thread
Tags
9-5, acc, blend door, code, fault, saab
