Few problems - The Saab Link Forums
Old 08-12-2009, 07:23 AM   #1
Kad
Few problems
1. Ok yesterday i was driving in traffic maybe 20 mph and brake reeeeealy hard and my engine stals. Anybody know shuld i worry or not , what could it be?
2. I get messages on my SID - " brake lights falure" but all the lights working normaly ,cant find a problem, any idea?
3. Also i get - " low washer fluid" and "coolant fluid" - i guess sensors died ?
4. One more thing , my remote dont work , also light "fasten seatbelts" of, child protection on doors dont work is all this controled by TWICE or not ? Could it be that twice faulty ?
5. My ac compressor its loud on idle when car its on Drive or Rear on nuetral or parking not , and car is vibrating. I did replace all mounts about 6 month ago and compressor its year old .My tensioner old but with new pulley on it, could this be bad tensioner or shuld i change compressor?
Thanks guys.
Kad is offline
Old 08-13-2009, 04:31 PM   #2
Kad
i guess here nobody knows )))) oh well thanks anyway
Kad is offline
Old 08-13-2009, 05:40 PM   #3
everyone is at SOC Colorado, so it is a slow weekend.
is your washerfluid/coolant low? If they are not then bad sensors.
not sure about anything else.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 08-13-2009, 05:45 PM   #4
mike9000aero's Avatar
i see this at the shop all the time, brake light failures when there arent any are normally due to having differant brand bulbs in....normally we just replace all the bulbs in that circuit with new of the same brand and it is fixed, as for winshield/coolant warnings, check fluid if good and up bad sensors i would guess
mike9000aero is offline
Old 08-13-2009, 06:16 PM   #5
Most likely one of the bulbs is shorting out and needs to be replaced. When the light it on I would put something heavy on the brake pedal and check back there to see which bulbs keeps going out. I had the same problem, and i found out which bulb was causing the problem. One time it would be on and other times it would go off. If thats not the problem then it could be a issue with the harness, I would check that also.
SaabBlackMan is offline
Old 08-13-2009, 06:31 PM   #6
BurnsSide42's Avatar
Or the SID isn't programmed properly - was it recently removed/replaced?
Agree with the wrong bulbs - happens often, usually melts tail lights and circuit boards as result....
Check out
for your repair needs
BurnsSide42 is offline
Old 08-14-2009, 06:14 AM   #7
Kad
i had bad bulb before in the "roof" brake light ,and i was geting message once in 2-3 days, then after i replaced all of them i get this every time(
Kad is offline
