Ok, i think i hate this car already =( - The Saab Link Forums
Old 08-10-2009, 08:16 PM   #1
So i got my '99 9-5 a little less than a week ago. First the left turn signal only wants to work some times, but lately doesnt work at all. Then the head lights are on all the time(when the ignition is on). The fogs go but can also be switched on/off b the high beam control(which doesnt turn the high beams on btw.) And the alarm started going off randomly so I unplugged the sirens, but now the flashers go off if i lock the car with the remote. ANd my horn doesnt work but all the fuses and relays are good.
My SID display doesnt work and i tried to fix it but some idiot that had the car before me, ripped the ribbon off when trying to fix it and taped i back on usng scotch tape.
If anyone has any suggestions that would help Id greatly appriciate it.
Thanks,
Tony
BLK4DR is offline
Old 08-10-2009, 08:27 PM   #2
jk88's Avatar
re: headlights always on: I don't know if it's the same in the 9-5, but on my '02 9-3 I never touched the headlights. It had daytime running lights, and at night, the ambient light sensor would kick on the normal headlights.
re: high beams/turn signal: If your high beams and left turn signal are on the same stalk, that could just need replacing.
re: alarm: Do a search on the alarm issue. A couple people have had that problem here and could surely point you in the direction of repair.
re: the SID: Take it out, check the part number against the list at the link below, order the repair, and send it in. You'll get it back 100% in less than a week with a lifetime warranty for ~ $85. http://www.bba-reman.com/catalogue/P...x?category=589
That should at least cross a couple things off the list.
jk88 is offline
Old 08-10-2009, 08:31 PM   #3
thanks for the link.
BLK4DR is offline
Old 08-10-2009, 08:44 PM   #4
adidas_007's Avatar
The daylight running lights can be turn off by the removal of a fuse from the drivers side fuse panel, it's fuse # 35 on the 9-5
As far as your Highbeams it may be the orange relay under the hood, give it a wiggle, hen try your lights.
The alarm may keep going off cause the batteries inside the alarm box are low, there is a way to DIY replace them http://photo.platonoff.com/Auto/2007..._Alarm_Module/
2010 9-5 Aero
2004 9-5 Aero 5pd Stg 3 Wagon, 1 of 18 Made
1990 900 Convertible
2007 Cbr600
adidas_007 is offline
Old 08-10-2009, 09:13 PM   #5
ok ill check the relay tomm. And I unplugged the siren box/black box for the alarm.
BLK4DR is offline
Old 08-11-2009, 02:49 AM   #6
could my alarm problem be that my winsheild is cracked pretty bad?
BLK4DR is offline
Old 08-11-2009, 04:54 AM   #7
GA
GA's Avatar
No, the siren going off at random is the classic symptom of a bad alarm battery. I've never heard of a cracked windshield setting off the alarm -- if the windshield is solid enough to deflect air at speed, it should not be triggering the alarm.
The alarm unit is located in the left front fender, and you can disconnect it to solve the problem, although you'll get the "Service Theft Alarm" message every time you start the car.
You mention disconnecting "sirens" plural - the other one is the horn. Which is why the horn no longer works.
The external battery in the alarm box is a US-only feature, designed to allow the theft alarm to work even if the main battery is disconnected. There is a way using the Tech II to re-program the car into "Euro-alarm mode" which stops the car from looking for the external alarm box, and stops the "Service Theft Alarm" messages on the SID.
The flashers should flash when you lock and unlock the car with the remote. That is normal.
GA is offline
Old 08-11-2009, 05:36 AM   #8
Moonracer's Avatar
This sounds like someone who shouldn't be trying to fix his own car!!
Moonracer is offline
Old 08-11-2009, 05:52 AM   #9
listin I was a tech at mercedes benz for 2 years now. I think Im well capable of working on my own car, thanks. What I ment by sirens is there are two openings on the black box making the siren plural (sirens). And Im not a retard I didnt unplug my horns.
The reason I asked about the windsheild is cause I heard that the windows have a break sensor for the alarm to sound if someone tries to break-in through the window.
And I realize the flashers go off when you lock and un lock the car, but they shouldnt go off for no reason, right?
BLK4DR is offline
Old 08-11-2009, 06:24 AM   #10
Moonracer's Avatar
Then you should know to read up on what your fixxing before doing it!!!!! The glass breakage sensor is for shattering glass, not cracked windshields. Get ahold of a tech-2 and eliminate the siren from the system or you will have alot of random light, and horns. The daytime driving lights are on all the time unless the fuse is pulled, turn on the headlight switch to alow the highbeams and fog lights to opperate, if the highbeams fail to opperate with the headlight switch on then the orange relay (lamp control) is faulty. Alot of times you can take the cover off the relay and resolder the connections on the board. As far as your SID, get a used one and get it fixxed if it's not working. The coil spring for the air bag is most likelly bad, causing your horn to not work, we're starting to see more of this.
Old 08-11-2009, 06:51 AM   #11
GA
GA's Avatar
I should point out that when you disconnect the external alarm box, the car uses the horn for its alarm/lock-unlock chirp. So when you said you had disconnected "alarms" I thought you meant the horn, too.
GA is offline
Old 08-11-2009, 08:43 AM   #12
I was trying to read up on it but most of the threads on here are dead end, like the op doesnt follow up with the post to say what fixed the problem. But ok thanks for hte help. My windsheild is shattered on the bottom. Like something smashed the bottom of it and now its cracking all the way accros.
And I was reading up on the SID thing, I think that if I am correct, if the SID is damaged the horn will not work along with some other things. Or is this just if its not installed?
BLK4DR is offline
Old 08-11-2009, 09:12 AM   #13
Moonracer's Avatar
Don't quote me on it but I don't thing the SID has anything to do with the external horn. The SID does controle all of the chirps, bells and clicks inside the car though. If the ribbon has been disconnected throw it away and get a used one. You will fight it forever. The only time the windshield being shattered would have effected the alarm is when it happened.
Old 08-11-2009, 10:30 AM   #14
oh ok. so can i just get a clock spring from another car or is it something i should buy new? and how much do they usually cost? Could that be the problem with my horn?
BLK4DR is offline
Old 08-11-2009, 10:50 AM   #15
Moonracer's Avatar
We've seen the harness in the sreering wheel go bad and the clock spring. There is a sat procedure to installing a used clock spring, normally we are very apprehensive to put used ones in customers cars. They don't seem to last long used. First you have to check you steering wheel though before condeming the clock spring
Old 08-11-2009, 11:01 AM   #16
ok how would I go about getting to the horn switch? I tried taking the airbag off but the saab setup is different from other cars.
BLK4DR is offline
Old 08-11-2009, 11:21 AM   #17
Castor Troy's Avatar
removing the airbag is easy.
disconnect battery(!!)
there are 2 screws in the body of the steering handle. one at 3 oclock and the other at 9; they are covered by plastic inserts
disconnect airbag and remove
Castor Troy is offline
Old 08-11-2009, 11:22 AM   #18
Kad
get a scruedriver and there 2 bolts on the side of the weel them out and you will see what next , disconect battery first or you will get Airbag Light and probably will need to take your car to tech 2 to fix that.
Flashing lights , hapen to me once about 2 years ago and never again, its maybe some thing to do with TWICE module ,got to check with tech 2 , or it could be glass sensor , i think sensor is inside passenger light over head , not sure.
Kad is offline
Old 08-11-2009, 11:39 AM   #19
Ok well im gonna try to get a new SID here soon. willthe dealer charge me just scan my for codes?
BLK4DR is offline
Old 08-11-2009, 11:54 AM   #20
Moonracer's Avatar
You said you are a Mercedes tech? What would your shop do? Of course they will charge you!!! Nobody works for free.
