This is getting old really quick - The Saab Link Forums
Old 07-15-2009, 07:34 PM   #1
Moreboost's Avatar
The turn signals decided to stop working today. I checked the fuses and everything looks good, the hazards also work. Im stumped
HELP ME plz
Moreboost is offline
Old 07-15-2009, 07:40 PM   #2
Harvey's Autohaus's Avatar
Unplug the Battery and Let Twice go to Sleep. Retest in the morning
HakbarSAABzzz
Harvey's Autohaus is offline
Old 07-15-2009, 07:42 PM   #3
Moreboost's Avatar
alright ill do that right now, thanks harvey
Old 07-19-2009, 10:50 AM   #4
Moreboost's Avatar
no luck, what else could be the problem?
Old 07-19-2009, 11:28 AM   #5
Is the stanchion for the blinkers messed up? I've had problems with mine in the past, and I've read about them breaking... both the plastic piece itself, and the wiring going through the column.
Otherwise I have no idea :/
Aero02 is offline
Old 07-19-2009, 11:37 AM   #6
Moreboost's Avatar
i dont think so, i guess ill have to pull the steering wheel off and take a look
Old 07-19-2009, 12:00 PM   #7
turbojohnny's Avatar
did you check your blinker fluid?
turbojohnny is offline
Old 07-19-2009, 12:04 PM   #8
Moreboost's Avatar
that was the first thing i checked, i topped it up dont worry
in fact if your curious i used this, amazing stuff i tell you. You cant even hear them blink
Old 07-19-2009, 12:22 PM   #9
well then how about the bulbs, it's an off chance but you never know.
Old 07-19-2009, 12:30 PM   #10
BurnsSide42's Avatar
Sedan or Wagon? If sedan - it is possible for the trunk harness to break and short out the system - usually just a blown fuse and a harness repair corrects this, but typically it's "some lights" not an entire system as a symptom - worth a peek however.
The SID & Twice also control this function - has your SID been "repaired" recently?
Check out
for your repair needs
BurnsSide42 is offline
Old 07-19-2009, 07:37 PM   #11
Moreboost's Avatar
Ill take a look at the harness, but iv only noticed the turn signals not working, and its not the bulbs because the hazards work. The SID i repaired a while ago with some felt, ill disconnect it and see if its that
Old 07-19-2009, 07:41 PM   #12
Castor Troy's Avatar
i'll give you $750 for the car inram
Castor Troy is offline
Old 07-20-2009, 04:41 AM   #13
someguy's Avatar
Send a message via AIM to someguy
$751.
Also I found a diagram that should help.
President and Founder of the NJSA- "We bring nothing to the table."
1999 M3 Cabrio
someguy is offline
Old 07-20-2009, 04:50 AM   #14
are hazzards and turn signals on the same relay? My turns work, buy I haven't had hazzards for over a year.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 08-09-2009, 09:32 AM   #15
Moreboost's Avatar
I finally got around to taking a look at the 9-5. I pulled off the airbag/steering wheel and changed the turn signal switch i had laying around. Put everything back together and same issue, no turns. The rest of the switches work, high beams cruise control etc etc. Iv looked at the fuses and i cant find anything wrong. What else could it be? Iv let the car sit overnight with the battery disconnected but still nothing
Old 08-09-2009, 09:49 AM   #16
bsuarmy's Avatar
Finish your engine.
Also...$752
bsuarmy is offline
Old 08-09-2009, 12:43 PM   #17
Did you try what Burnsside said? The trunk harness?
Aero02 is offline
Old 08-09-2009, 07:15 PM   #18
mine only work with the rght turn signal. left worked yesterday, but not at all today? could it be the whole turn signal stalk? like the lever for the signals is bad?
BLK4DR is offline
Old 08-09-2009, 07:19 PM   #19
i agree with trunk harness
my dad had this same issue.
ripped apart the trunk, and about 1/4 of the trunk wires were creased, had the sheathing ripped away, or simply cut in half
Old 08-10-2009, 06:01 AM   #20
could this problem be from the fact that my SID display isnt functioning? like its blank.
BLK4DR is offline
