Bought a 2k 9-5 Aero last night, minor probs with exhaust smell in cabin and... - The Saab Link Forums
Old 01-29-2009, 05:45 AM   #1
I bought a 2000 9-5 Aero from the second owner who was a female doctor so the car was very well maintained I have a stack of service records with it. It just turned a 100k. The car is a 5spd and sometimes can be difficult getting into reverse. All the gears shift very smoothly and reverse does work perfect too however sometimes it is difficult to get the vehicle into reverse. Also there is a smell of exhaust fumes inside the car with the heat on and finally the rear-end seams to sway a little if I hit a bump on the highway. Other than that the ext/int are in excellent shape now my dilemma is weather or not to sell my 98 9000 CSE 5spd.
loup1276 is offline
Old 01-29-2009, 06:12 AM   #2
NahumCC's Avatar
Oh keep the 98 9000. Its an aero without having the aero body or interior and since its a 5spd you have the much desired #6 td04 turbo (full aero power).
As for the 9-5's issues. Check the exhaust for holes or damaged flexpipes as the fumes may be getting pulled in via that A/C intake. For the rear I'd look at the bushings and make sure they aren't worn out.
2013 FR-S
NahumCC is offline
Old 01-29-2009, 06:15 AM   #3
GA
GA's Avatar
The sway in the rear is the classic sign of the rear shocks going out. Those go out early on the 9-5, I replaced them at about that mileage on my 2000 9-5 Aero.
GA is offline
Old 01-29-2009, 06:50 AM   #4
Thanks guys.. any Ideas on the trans having intermittent difficulty going in reverse? And I think I am most likely going to keep the 9000 I just installed the JT 3" turbo back and got my K&N intake from Genuine Saab and 3.0 fuel regulator I gotta order a 3 inch universal cat... after that I am going to purchase a JZW Stage 3 ECU...
loup1276 is offline
Old 01-29-2009, 06:59 AM   #5
NahumCC's Avatar
Well thats an issue with the reverse gear shaft. If the setup is the same way in the F35 as it is in the f25 (9-3 s/se gearbox). The following below is a summary of the f25 gearbox reverse from wis.
Reverse gear has its own shaft in the gearbox which holds a reverse gear wheel and a reverse gear pinion. Basically the reverse gear wheel is constantly messed with 1st gear pinion. The reverse gear pinion is constantly messed with the 1st/2nd gear syncromesh sleeve on the output shaft. There is also a syncromesh on the reverse gear shaft to match up the wheel and pinion so that the rotation is transferred from the input shaft to the output shaft.
So in essence if your only having problems with reverse then your issue could be isolated to the reverse gear shaft and the syncro there. Otherwise if your starting to have issues with 1st and 2nd grinding that could also be the location of the issue.
2013 FR-S
NahumCC is offline
Old 01-29-2009, 07:43 AM   #6
Saab99Super's Avatar
Many times the trick to reverse is instead of shifting straight from N to R, go 1st to 2nd then R. Something I've had to do on lots of stick 9-5's and almost anyone with a 5spd c900 has probably had to do that to.
1979 99 GL "99 Super"
1999 S10 ZR2
1991 Mazda Miata
78' Turbo
Saab99Super is offline
Old 01-29-2009, 07:56 AM   #7
Ive heard that before I guess it aligns the syncros Ive been trying to research the problem it seams the shift linkage may be a possibility for my problem. Apparently there is a Saab specific tool that is used to align it. I think there is also a retro part kit as well. Can anyone confirm this?
loup1276 is offline
Old 01-29-2009, 09:14 AM   #8
stromer's Avatar
I would bet it is just a shifter lineage alignment issue if you're just getting resistance and not actual grinding.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 01-29-2009, 09:44 AM   #9
jssaab's Avatar
uuhh WRONG
All wrong ( I wish people would refrain from guessing about issues unless they have the data) I remember being confused by all the guessing replys when I forst posted problems years ago... not to be a hard @ss or act like I know any better, it just makes it easier for a first timer if you dont guess... and I have lived through this
The early 9-5 tranmsission ( yours 2000 like mine) have an update kit that is to be used if you see any of the problems on the list here:
Complaints Parts Part Number
Blocked 2nd gear Synchromesh hub 1-2 51 64 041
Blocked reverse gear Reverse Leaf spring Kit 52 57 910
Difficult to engage 3rd-4th gears Synchromesh rings 3rd-4th
Reinforced shift fork 3rd-4th
Leaf springs x6 51 60 296
87 49 749 (Kit # 54 40 524)
87 43 791
Difficult to engage 5th gear Synchromesh sleeve 5th Synchromesh ring 5 th
Leaf springs x3 52 59 353
51 61 005 (Kit # 54 405 532)
87 43 809
Difficult to disengage 3rd-5th Selector bearing bracket 54 40 144
You are describing the "blocked reverse gear" symptoms... classic...
Link to Genuine Saab transmission TSB
Another thing you can try ( that is easier than rebuild with the update kit) is to change the manual transmission fluid to the new Saab MTF 0063 ( if it has not been cahnged already) Check you rrecords. This fluid will greatly improve shift quality in early transmissions and its realtively easy DIY
Try the fluid change and see if that helps first:
New Manul Trans fluid change
jssaab is offline
Old 01-29-2009, 10:11 AM   #10
I am going to start with the fluid flush/change... jssaab you indicated you have the same year car, did you ever have these issues and if so did the Saab MTF 0063 help at all?
loup1276 is offline
Old 01-29-2009, 11:40 AM   #11
jssaab's Avatar
Yes I had these problems and the MTF helped a lot... Make sure you follwo the drain and fill instructions ... I did eventually rebuild it with a Quaiffe LSD and the kit... and it now is smooth as silk ( like my 03)
jssaab is offline
Old 01-29-2009, 11:43 AM   #12
Since it looks like jssaab has the trans issue covered, I would re-iterate that in all likelihood the exhaust smell is from a leaking flex pipe.
Aero02 is offline
