Aero wagon w/slight shimmy at speed - The Saab Link Forums
Old 04-02-2005, 03:28 PM   #1
I've just recently purchased a 2001 Aero Wagon with original Aero wheels and a set of new Michelins. The car is great up to 110 km/h or so, but anywhere between 115 km/h and 140 km/h there is a very very 'slight' shimmy (I can only further describe it as un-smooth or driving over mildly rough pavement) - felt both via steering and seat with a very low, "spinning washing machine" sound - just enough to make a long drive at those speeds uncomfortable (and a bit unnerving not knowing what it is).
The car has been back to the dealer 3 times for wheel balancing. The last time they replaced one of the wheels, both front rotors and did a really fine tune on the wheel balance machine. While I did get a slight improvement, the problem is still there.
I feel like I'm being picky, and this is the first time I've owned a car with performance wheels and tires (I had an '02 Volvo Cross Country before the Saab).
What should I do?
gravy is offline
Old 04-02-2005, 10:46 PM   #2
adidas_007's Avatar
It does sound like the tire mounting went bad somewhere.
If you do go back again try to get them to remount your tires, I had the same shimmy problem, but after new tires its gone. Or maybe a bad tire?
2010 9-5 Aero
2004 9-5 Aero 5pd Stg 3 Wagon, 1 of 18 Made
1990 900 Convertible
2007 Cbr600
adidas_007 is offline
Old 04-02-2005, 10:54 PM   #3
Administrator
Boxerchip's Avatar
yeah man, if they know the rims are not bent and the axles are not bent it has to be a tire. take that shit back and make them do it right, test drive the car before you pay and or leave the dealership and make sure the problem is gone.
1998 BMW M3-ECU, intake, tein coils w/ pillow ball uppers, sway bars, W7 w/ 1000 watt JL, short shift, DSSR, uuc exhaust, BBS CH 18s.
2001 Audi S4-Sold
1999 STAGE III VIGGEN-Sold
2000 9-3-Sold
1992 900S- Sold
Boxerchip is offline
Old 04-03-2005, 05:11 AM   #4
One of those front tires could be defective. Switch the rears to the front and do a road test.
A front wheel with a slight dent will definitely cause annoying vibration at speed. This happened to my current set of winter wheels, so I put the fronts on the rear and I've been problem free...
If you can get a service history on the car, check to see if any of the front suspension components were replaced, or if a tire/wheel was ever replaced at the dealership. That could indicate the previous owner whacked a curb pretty hard and may have bent something. This is probably very unlikely, but still worth checking.
Old 04-03-2005, 08:36 AM   #5
Thanks guys. I've lost faith in the dealership to resolve the problem - I drive away and it seems OK, but then a few days later, when I get to cruise a long stretch of open road, there it is again.
Are there shops that can do the diagnoses you've suggested above in one shot (axle, wheel, tire , etc...) and be able to rebalance the wheels with a road-conditions-type test (preferably one that can reach simulated speeds between 110 km/h and 140km/h+)? Maybe another dealership? Up here, the dealerships are Saturn Saab - emphasis on Saturn.
I'm thinking I should simply replace all the wheels, or get the old ones 'touched up' (rebuild or fix scuffed rims).
gravy is offline
Old 04-03-2005, 12:17 PM   #6
Hey gravy welcome to the site,
I see you're from toronto...what dealership is it that you take it to?
I've had bad experiences with Midtown....Thornhill saab is the best bet and the favorite around here, I can also reccomend some of the best independant saab garages in GTA.
Spray is offline
Old 09-17-2005, 06:25 PM   #7
Same problem.
the stock aero wheels shimmered around the same speeds you are mentioning.
we went through 3 sets of tires and countles trips back and forth to get the wheels re balanced.
if you have the resources check your rim with a Dial indicator gauge..
if u cant get a hold of one of those.
you may be out of luck in knowing your problem.
also it could just be the fact that since you said u have summer tires on the lower and stiffer sidewall is transferring more vibrations into the car. try lowering your tire pressure as a last resort to around 30-32 P.s.i. tire wear may be a bit worse, but it should 'moosh' up the ride somewhat.
Mr.Dobsi is offline
