bright red catalytic converter - The Saab Link Forums
Old 11-03-2008, 04:58 PM   #1
explorerfx4's Avatar
Send a message via AIM to explorerfx4
tonight i was coming home as normal, i was kinda gettin into it a little, but nothing extreme. my EGT gauge was reading normal, nothing out of the ordinary happening, when all the sudden i lost all power and couldnt accelerate, the CEL started flashing, and i coasted to a stop (luckily at my house) and the car wouldnt restart. so one i get out i notice a bright red glow from underneath the car. only to see that its my converter. what the hell does this mean for me? and yes, im going to double post at SC too here are some pics
explorerfx4 is offline
Old 11-03-2008, 04:59 PM   #2
Moreboost's Avatar
your egt was reading normal? thats weird, no idea whats going on sorry, must look pretty cool though
Moreboost is offline
Old 11-03-2008, 05:00 PM   #3
Lendo's Avatar
Looks like a UFO picture.
Lendo is offline
Old 11-03-2008, 05:02 PM   #4
Deez Nutz
Palmer's Avatar
Your cat is clogged.
A chunk of catalyst came loose inside, and is blocking exhaust flow.
Try tapping on it with something, I bet it rattles.
Time for a new one.
S55/LC100/KL
Palmer is offline
Old 11-03-2008, 06:15 PM   #5
oliversexpedition's Avatar
Good reason to use a "test" pipe
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 11-03-2008, 06:17 PM   #6
turbojohnny's Avatar
cut it out, hollow it out, and weld it back up
edit: actually on your 9-5 you probably need to have a catalyst for o2 sensor readings
turbojohnny is offline
Old 11-03-2008, 06:21 PM   #7
Moreboost's Avatar
iv always wanted to know why they call it a test pipe, any ideas?
Old 11-03-2008, 06:32 PM   #8
to test how the exhaust would sound and the engine would perform without a cat in it.
just a guess
Old 11-03-2008, 06:46 PM   #9
what palmer said or maybe you are running WAY rich
running rich or a serious overfueling problem can cause a cherry red cat too. you'll probably notice it running like crap then tho.
Nashvegas is offline
Old 11-03-2008, 07:49 PM   #10
DeLorean's Avatar
misfire condition will cause this, your DI probably dropped dead.
DeLorean is offline
Old 11-04-2008, 05:07 AM   #11
i think you are spot on sir, i popped off the DP today and tried to start it, and still nothing, but it wreaked of gas, telling me that im getting no spark whatsoever, and thinking back i have noticed that my car has been taking a lot longer to start. ill be getting a new DI hopefully today and see what happens.
Old 11-04-2008, 06:02 AM   #12
JK
JK's Avatar
no spark + cranking the car over to try to start it + hot cat = nice warm glow
always a SAAB guy at heart
JK is offline
Old 11-04-2008, 08:31 AM   #13
Here's my theory:
When cars had carburetors and no engine diagnostic equipment, people would install a "test-pipe" to see if the cat converter was the reason behind the poor running vehicle. They would remove the old cat, install the piece of straight pipe, and see if the car ran/ performed better.
If it did, the cat needed to be replaced. A poorly tuned carburetor will lead to the rapid destruction of a catalytic converter due to raw fuel being dumped into it.
Jason
'05 9-5 Aero: Black. Tinted windows & SportTech CF. Sold on 6-28-10
'04 Jeep Grand Cherokee: 2" lift & thirsty V8
JeeperJay is offline
Old 11-04-2008, 12:08 PM   #14
sounds like a strong theory to me
i say we go with that
Old 11-04-2008, 12:41 PM   #15
Ive always thought it came from fabbing up a new exhaust and test fitting it. You don't want to weld the cat to the piping before you know how its all going to fit. So you create the piping with no cat, mark it, cut and then weld the cat in.
Either seems reasonable. Both could be wrong
Also, DeLorean is right on the money, as usual, I'm sure.
Aero02 is offline
Old 11-04-2008, 12:48 PM   #16
ill be picking up a spare DI that Ben (tweek) has tonight to use and see if that is the cause of my problem. and ill prob be buying a new DP as well to replace the cat.
Old 11-04-2008, 12:53 PM   #17
c900 Grognard
Jack Straw's Avatar
With the "test pipe" nomenclature, I think it is because no car is really supposed to have one. They are sold for "off road use only" and I'm guessing it could mean that it is for "testing purposes only" ie, a way to justify selling them.
Originally Posted by IronJoe
Jack Straw is offline
Old 11-06-2008, 01:57 PM   #18
well i put the new DI in and my car runs good now, however, now im getting a P0420 which tells me that the cat isn't working very good anymore. time for a 3" DP
Old 11-06-2008, 03:00 PM   #19
Glad it's working, don't forget its a pre-recall unit too, so I have no idea how long it will last.
Old 11-06-2008, 04:20 PM   #20
oh yea, i know, your extra one has the same software that mine had. i actually found a guy on ebay from sterling selling a DI but i haven't been able to get up with him to see what software version it is.
