Fuel pressure cut off? - The Saab Link Forums
Old 10-22-2008, 12:35 PM   #1
First off I'd like to say Hello to everyone
A bit of history on my car, 03 motor, just replaced DI and spark plugs.
I have had the boost issue for sometime now, and I don't know if I decided to try hauling ass too soon after replacing the DI ( 20 minutes after replacement ) or what.. but NO CELS.
So at random times my car decides to abruptly hesitate under hard acceleration. A jolt 'N go process...
Some background on my car..
First gear from the pit boost moves up to 15 psi until shift and then the car dies. The car instantaneously goes to 4 psi and then slowly builds up to a maximum of about 8 psi. Then the shift into third and I will maybe hit 10 psi.
If I floor the car at 40 it will go to 15 psi and then go straight down to 6-7 and stay there..
I notice if I let off the gas and press it again fairly quickly the car will hit 16 psi and hold it.
I checked the BCV.. The spring in itself is very hard to push, so that rules it out.
Being able to hold 15 psi in first and not any other gears rules out the wastegate, although in higher gears when it spikes to or over 18 I think the wastegate can play a small part in this problem at that time. Vacuum lines have been replaced, except the one from the front of the throttle body to the back of the black box ( about a foot long ) And the one's that my boost gauge line is T'd off of.
-Derek
wiSpeel is offline
Old 10-22-2008, 12:42 PM   #2
drewz airflow se's Avatar
Have you checked the BPC?
^CLICK ME^
drewz airflow se is offline
Old 10-22-2008, 12:49 PM   #3
"So at random times my car decides to abruptly hesitate under hard acceleration. A jolt 'N go process..."
This has apparently ceased all action. Very peculiar.. Could this have just been the result of hard acceleration on a new DI?
How would I go about testing the BPC?
wiSpeel is offline
Old 10-22-2008, 01:25 PM   #4
NahumCC's Avatar
No a failing DI will do that where it bogs down as it can't get the spark going and then it all clicks. Had that happen twice now with failing DI's. Generally when it happens you'll also get the flashing CEL noting misfire.
2013 FR-S
NahumCC is offline
Old 10-22-2008, 01:34 PM   #5
Well it isn't bogging down, as I remember what that was like before it completely went out on me. I remember because I would press the gas to accelerate and it wouldn't go any faster, followed 30 minutes after by rough idle etc.
Any takes on the boost issue, I am fairly fed up with this as it has been six months like this.
wiSpeel is offline
Old 10-22-2008, 02:53 PM   #6
Moonracer's Avatar
Is your car an Aero?
Moonracer is offline
Old 10-22-2008, 02:53 PM   #7
Yes
wiSpeel is offline
Old 10-23-2008, 04:54 AM   #8
Moonracer's Avatar
Part of the reason you are seeing the boost spikes is that the Aero versions have a over boost feature. It will alow them to boost more for a short time. this is to keep the pistons from melting. As for specifics as to how much your car should boost I would have to look it up. As for the cut out part, what type of spark plugs did you install? mabey try a new set again. I've been witness of new plugs causing this problem. Try to start simple first. Good luck
Old 10-23-2008, 05:13 AM   #9
Only manual models feature over boost friend :]
wiSpeel is offline
Old 10-24-2008, 04:38 PM   #10
So that is it for advice huh.
wiSpeel is offline
