How do you pull the Axels from a 9-5? - The Saab Link Forums
Old 10-08-2008, 10:58 AM   #1
jssaab's Avatar
Pulling my engine soon, I have removed the power steering pump and AC. Gotta take the axles out but I can't see how to pull them. is there a lock ring or something and then they can pullout of the spline?
jssaab is offline
Old 10-08-2008, 11:02 AM   #2
NahumCC's Avatar
Take a small crow bar and place it right behind the driver cup off the driver side axle at the diff housing. Should only need just a little force to get it to pop right out. Thats how I did mine. As for the passenger side I don't know what to suggest since I was pulling my trans out that axle came out on its own as I removed the trans.
2013 FR-S
NahumCC is offline
Old 10-08-2008, 11:06 AM   #3
jssaab's Avatar
That's what I was thinking about doing but was afraid I would screw it up thanks Nahum...
jssaab is offline
Old 10-08-2008, 11:09 AM   #4
NahumCC's Avatar
You'll be fine. Like I said just use a small one to get in there and it'll only take a little bit to pop out the splines from the diff on the drivers side. If I was at my computer (up on campus) I'd look up in WIS on what to suggest for the half shaft that runs from the passenger side of the diff to the passenger axle.
2013 FR-S
NahumCC is offline
Old 10-08-2008, 11:14 AM   #5
NahumCC's Avatar
Looking at Eeuro and their break down photo of the axles I'd be willing to bet you could do the same thing at the passenger side driver cup where it meets the half shaft axle in the support bracket. Trying to find a in car picture of the axle setup to confirm.
2013 FR-S
NahumCC is offline
Old 10-08-2008, 11:24 AM   #6
jssaab's Avatar
Will do thanks...
jssaab is offline
Old 10-08-2008, 12:49 PM   #7
Jssaab, wish I could be more help. It was more than a year ago when I pulled the 9-5 axles for my rebuild.
I do remeber the drivers side pulled right out. I disconnected the lower ball joint (three bolts) and pushed the lower controll arm down to free it. Then I pulled the whole strut assembly away to get the spline out of the hub. Then I just pulled on the axle like Nahum has suggested and it came out.
The pass side was different!!! You know it is in two section? ONe section is straight and rides in some sort of carrier bearing around where the alternator is. The other side is a normal axle with to cv joints. I was trying to pull the axle out with no luck. I got under there and saw a HUGE c-clip holding it it. My crappy Harbor freight c-clip pliers were bending under the load of the clip. What I ended up doing is cutting the clip with a die grinder, and then picking it out.
Since you have the alternator out, I would suggest removing the bracket that holds that carrier bearing in. The straight shaft pulls right out of the tranny.
When I put it all back together, upon examination of the halfshaft I couldn't figure out HOW that c-clip actually retained anything.
Im going to look in WIS right now though, you've got me curious. Of course, the c-clip did NOT go back in
Tboy
Tboy is offline
Old 10-08-2008, 12:59 PM   #8
OK it looks like the C-clip removal was not necessary. Wish I had the wis before. The C-clip captures the intermediate shaft bearing (which is also press fit). There is one on either side of the bearing. Wis just says to drive the shaft out with a brass drift hammer. It should have come out just like the drivers side. Mine didn't.
Guess I should also get one of those c-clips and put it back on the carrier bearing!!
Tboy
Tboy is offline
Old 10-08-2008, 12:59 PM   #9
Azrael's Avatar
Hit the eject button to get the Guns N' Roses album out.
Originally Posted by Hirsch
If you grab a tiger by its tail, you better be prepared to deal with the fucking fangs on the other end.
Azrael is offline
Old 10-08-2008, 05:27 PM   #10
jssaab's Avatar
Tboy
Thanks Tboy that will help too, going to get back at it on Sat
RLMAO ...
jssaab is offline
Old 06-05-2010, 09:57 AM   #11
I know this post is a couple years old, but I'm running into a problem trying to get the drivers side (left) drive shaft removed from the transmission. I've exerted a lot of pressure with pry bars, but without any luck. Any suggestions are welcome. Thanks!
Regards,
Gregory Bender
Gregory Bender is offline
Old 06-05-2010, 11:33 AM   #12
It's actually very easy, and I've never use a pry bar to do this. It just requires a bit of strength. Since the splines are meshed with very close tolerences, any force applied to them will result in a lot of friction. What I do is line up with shaft so that it is perfectly straight at both ends and give one powerful tug. This will only work with the CV boots holding everything together.
fong is offline
Old 06-06-2010, 04:05 AM   #13
Hi fong,
I first tried the "one powerful tug" method, and ended up separating the inner crosses from the inner driver, leaving only the inner driver connected to the transmission. I proceeded with pry bars, being as careful as possible to exert equal force on either side. I was able to exert significant pressure, but it wouldn't budget (not with sudden pressure, nor with slow and easy pressure).
Finally I decided I would end up breaking things I really didn't want to break. So, I just fit my new axle into the existing driver and called it a day.
A perfect solution? No. But a whole lot better than needing to pull the transmission.
Regards,
Gregory Bender
