How do I rebuild an e-brake? - The Saab Link Forums
Old 09-09-2008, 01:17 PM   #1
chriscam84's Avatar
Send a message via AIM to chriscam84 Send a message via Skype™ to chriscam84
So this happened: https://saablink.net/forum/showthread.php?t=31348
And then I ordered a new ebrake hardware kit and new ebrake shoes, but I have no clue how to rebuild the e-brake system. There's like 10 little pieces of hardware per side and I'm at a loss. Does anyone know of or have a DIY guide or step by step?
Thanks in advance,
-Chris
2002 9-5 Aero JZW 5+
1999 9-3 Turbo
1995 900SE Turbo Convertible Nordic Stg II
1995 900S Convertible
chriscam84 is offline
Old 09-09-2008, 03:56 PM   #2
Trollerator
abdukted1456's Avatar
cheers
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 09-09-2008, 04:02 PM   #3
Trollerator
you'll want to have the rotor and caliper off, obviously. Also the bolt holding on the cable off or maybe slackened.
then:
put the brake shoes, adjusting lever, and adjuster on the backplate
fit springs for retaing pins and return springs (suggests special tool)
the one tool looks like a loop end probably to strech the spring with the hooked end, the other tool kinda looks maybe like a dental pick?
fit rotor and caliper
hook cable in place and fit return spring for it.
adjust handbrake (DIP has a good writeup with photos on his 9-5 rear brake job page)
fit wheels
depress brake pedal to force caliper piston back out etc
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-09-2008, 04:05 PM   #4
chriscam84's Avatar
Thanks Dan, that diagram really helps... But what about those nail looking parts that came with the hardware kit? I don't see them in the diagram.
1999 9-3 Turbo
Old 09-09-2008, 04:07 PM   #5
stromer's Avatar
Check out Dip's page!
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 09-09-2008, 04:39 PM   #6
chriscam84's Avatar
I'm there, but he doesn't actually remove/replace the ebrake components in his write-up
1999 9-3 Turbo
Old 09-09-2008, 04:58 PM   #7
Trollerator
if you look up the e-brake hardware kit on eeuroparts it says what the pieces are. the name of them should give a hint as to the pins function/placement IIRC
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-09-2008, 05:24 PM   #8
chriscam84's Avatar
Guys, I apparently fail at mechanicing... I still don't know how
THIS:
PLUS
THIS:
fits inside
THIS
I'm gonna go look at all the parts and try and figure it out!
1999 9-3 Turbo
Old 09-09-2008, 05:28 PM   #9
chriscam84's Avatar
I'm glad I posted that last set of photos, because I think I may have figured it out after looking at the hardware kit and that diagram that Abdukted posted.
1999 9-3 Turbo
Old 09-09-2008, 05:36 PM   #10
VWSAABVT's Avatar
The "nail" looking things go through the back of the dust cover and through the shoe, then you push the spring from #2 down with the little cup in #2 down over to hold the spring and shoe down and twist the cup so that the nail looking thing holds onto it.
hope that helps, a little run on, butg Im drunk
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-09-2008, 05:38 PM   #11
chriscam84's Avatar
Thanks man! Drunk advice is the best advice
1999 9-3 Turbo
Old 09-09-2008, 05:39 PM   #12
VWSAABVT's Avatar
also, take the other rotor/drum off the other side to see how it goes together if its not allready apart
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-09-2008, 05:46 PM   #13
chriscam84's Avatar
OMG, you're a genius!
hahahaha, I'm stupid.
1999 9-3 Turbo
Old 09-09-2008, 05:50 PM   #14
Trollerator
yes, definitel look at the other side and take a photo of it for reference, before you take that one apart too. (if you're doing both sides)
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-09-2008, 06:50 PM   #15
srp
srp's Avatar
Send a message via AIM to srp
I learned the hard way with drums. Never have someone help you and do both sides at the same time... What are you going to refer to when you forget where things go??
srp is offline
Old 09-09-2008, 07:17 PM   #16
chriscam84's Avatar
LOL, excellent point!
Alright, I work tomorrow, but this is happening thursday (along with a coolant flush, thermostat/coolant temp sensor swap, and trans oil flush), I feel much more confident about the endeavor now. I'll post up how things went thursday night!
1999 9-3 Turbo
Old 09-10-2008, 09:29 PM   #17
chriscam84's Avatar
Okay, new problem... I just spent a few hours on this and now I'm even more frustrated.
You see,
I ordered new e-brake shoes and the "hardware kit", however the hardware kit does not come with all the parts I need.
Here's the hardware kit:
here's the ebrake diagram:
The hardware kit does not contain the adjustment screw (figure 1) and the other thinggy that actually attaches to the ebrake cable (figure 2).
Here's what I have left over from when my e-brake asploded.
The big problem is that these two parts from my old ebrake that I need from my new ebrake are FUBAR...
I was able to get the adjustment screw back together. Figure 1A was crushed and and misshapened, figure 1B was all gouged up where it fits into figure 1A. After some hard work with I was able to get the adjustment screw back together (with a hammer, dremmel tool grinder, sandpaper and some patients).
Firgure 2 (the mechanism that attaches to the ebrake cable and acts on the shoes is unrepairable).
So now lies the problem. I can't seem to order a new 'figure 2' anywhere... and I need one to make my ebrake work. Anyone have any ideas?
1999 9-3 Turbo
Old 09-11-2008, 05:17 AM   #18
jssaab's Avatar
Yah you need to go to the dealer those are not general "wear" items that ever need replacing ( or a junk yard I guess)
Boy I am old, every car I had back in the day had drums ( and my TR6 stillhas them in teh rear...
jssaab is offline
Old 09-14-2008, 10:21 AM   #19
Trollerator
Chris let me know how this goes and what tools you use or how you are able to remove and re-install these little screws and pins.
I took the rear brakes off my wife's 99 today to do pads and rotors and found everything in tact except shoes have a paper thin layer of friction material on drivers side and just metal on the pass side!!!!
so I gotta do new ebrakes too
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-14-2008, 08:11 PM   #20
mcrowley's Avatar
dukted, want to help me fix the e-brake on my 900?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
