can auto tranny slip? - The Saab Link Forums
Old 04-09-2008, 06:01 PM   #1
Send a message via AIM to aero93
Hey is it possible for an auto tranny to slip like a clutch would?
aero93 is offline
Old 04-09-2008, 06:16 PM   #2
HIDSPG's Avatar
yes
88 SPG, 08 TX Combi
HIDSPG is offline
Old 04-09-2008, 06:21 PM   #3
depending on how bad, does that mean its going to go, is there a way to fix it without buying a new tranny/ stop it from slipping or breaking any further ?
thanks guys
aero93 is offline
Old 04-09-2008, 06:26 PM   #4
Rudedog's Avatar
Have you changed/flushed any of your transmission fluid since you've had the car. What year and how many miles do you have?
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 04-09-2008, 06:57 PM   #5
just got the car about 2 days ago, 2000 9-5 aero automagic, fluid looked okay but will change this weekend in any case it seems to rev and then catch when shifting from 2nd to 3rd while under full throttle it slips at 4k to about 3k and then climbs back up,
not sure
thanks for all the help and keep it coming, by the way i dont know much about my new car so i will be asking alot!
aero93 is offline
Old 04-09-2008, 07:04 PM   #6
Yes and its much more serious.... Either the oil pump isnt providing enough pressure to shift the gear or the clutches and bands are starting to slip....
Guteman is offline
Old 04-09-2008, 07:27 PM   #7
how long will it last? a while if i dont beat on it i assume, i can swap out the tranny when i can afford to buy a new one.
so there are no preventive measures ?? or anything i can really do?
aero93 is offline
Old 04-09-2008, 10:25 PM   #8
It could last a while, and could die soon. Change the fluid and drive easy. The bad thing about AT clutches is the friction material is very thin and once worn, thats it. I limped one around for a year before replacing it. Good luck
saabdrifter is offline
Old 04-10-2008, 07:17 AM   #9
JLausch's Avatar
Send a message via AIM to JLausch
not sure
Maybe i'm wrong here but if i remember on my '00 Aero it did that (always) when the torque converter locked up, maybe i'm reading your description wrong though, usually the revs go up when it slips, not drop.
I was referring to the 4k to 3k drop part, the slipping then catching i'm not so sure about.
'03 9-5 Aero wagon
'91 9000t (sold)
'90 SPG (sold)
'01 Viggen (sold)
JLausch is offline
Old 04-10-2008, 07:28 AM   #10
Trollerator
abdukted1456's Avatar
I had a bmw with auto tranny that slipped a little, and it went out about 4 minutes later. it slipped and then the next time I hit the gas, it slipped so bad i thought it was in Nuetral. I couldn't get it back into gear and had to pull off the highway with no acceleration available. It had to be rebuilt.
that was scary, trying to navigate my way off 787 during rush hour with only brakes and coasting.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 04-10-2008, 08:18 AM   #11
well the rpms will rise fast and then all of a suddent they will drop 1k rpms so it would rise quick to 4k and then drop to 3k and then go back up to 4k, is this right?
aero93 is offline
Old 04-10-2008, 08:39 AM   #12
JK
JK's Avatar
We don't know. Is that what it is doing?
My 9-3 w/ auto trans drops down about 1000 rpm when the torque converter locks up in 4th gear. That is the opposite of slipping, its catching, locking up, etc.
always a SAAB guy at heart
JK is offline
Old 04-19-2008, 06:20 PM   #13
numbersix's Avatar
The older 4 speed AT is not considered to be as robust as the 02-up A-W 5 speed model.
Have you pulled the dipstick to check the level, color, and smell of the fluid? Read your manual for proper fluid level check procedure first. The fluid should be full when read using the proper procedure; it should be pink and not smell burnt. If it is dark and smells burnt/fishy/etc, you likely have a problem. First step would be to try flushing the fluid and see if the slip persists.
JJB
...be seeing you.
numbersix is offline
