Oh no - The Saab Link Forums
Old 04-03-2008, 08:24 AM   #1
Unhappy Oh no
So i woke up this morning and decided to go for a drive. Upon arival home i could spy with my little eye
and im not talking about the quarter.
Its coming off the cat. I had gotten my oil changed about two weeks ago. could it be drain plug?
sorry about the photo size
Mr. D is offline
Old 04-03-2008, 08:26 AM   #2
drewz airflow se's Avatar
check to make sure the oil filter is tight.
^CLICK ME^
drewz airflow se is offline
Old 04-03-2008, 08:43 AM   #3
StX221's Avatar
Check down through the intake manifold. On the back of the block is the oil pressure sending unit. Those tend to fail and leak oil all over the place. Especially right onto the cat. You can also check from under the car. Best way to spot one is when it is up on a lift as you get the best view of it. Basically just look and try and find out where it is coming from...
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-03-2008, 08:47 AM   #4
jssaab's Avatar
What Nick said^^^, could be caused by high crank case pressure are you on PVC #6, was it overfilled at last oil change. Also cold have been bad pur of the oil but it was 2 weeks so prolly not
And trans output seals...
They can throw oil up on the engine and it runs down there
jssaab is offline
Old 04-03-2008, 08:49 AM   #5
this is what i got
Mr. D is offline
Old 04-03-2008, 08:49 AM   #6
JK
JK's Avatar
When I had the oil on the cat problem it was because of the oil pressure sensor leaking.
always a SAAB guy at heart
JK is offline
Old 04-03-2008, 08:53 AM   #7
yeah what STX said sounds like what your problem is.
^CLICK ME^
Old 04-03-2008, 08:58 AM   #8
Is this an expensive fix?
Mr. D is offline
Old 04-03-2008, 09:33 AM   #9
Do you DIY?
^CLICK ME^
Old 04-03-2008, 10:17 AM   #10
DeLorean's Avatar
had the same problem with mine, oil pressure switch fixed it. the part us under $5.00, installing it is a pain. I would imagine a dealer would charge around $100 for the job.
DeLorean is offline
Old 04-03-2008, 10:35 AM   #11
StX221's Avatar
I think the part is actually $18. Its a very simple fix, just unscrew the old one and put the new in place. The only tricky part is figuring out how to get a wrench on it, and getting your hands to it.
Edit: Just checked eeuro and BAM! $18.
http://eeuroparts.com/productdetail....s=1&code=10642
Guess I have a good memory for parts and the likes.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-03-2008, 11:10 AM   #12
chriscam84's Avatar
Send a message via AIM to chriscam84 Send a message via Skype™ to chriscam84
Sucks to see fluid under your car, doesn't it.
Hey, so I just realized we live in the same place and drive the same car (well, different color).
Race ya
2002 9-5 Aero JZW 5+
1999 9-3 Turbo
1995 900SE Turbo Convertible Nordic Stg II
1995 900S Convertible
chriscam84 is offline
Old 04-03-2008, 11:59 AM   #13
jssaab's Avatar
this is what i got
Hey does oil drip up???
There is a lot up around the exhaqust tunnel there. On my car the only time I got that was when the trans was leaking and getting oil on the drive shafts which threw it up thataway( but then again I guess it could be getting on the shafts from the sender as well)
jssaab is offline
Old 04-03-2008, 12:03 PM   #14
DeLorean's Avatar
yeah, it's the C-900 ones that are sub $5.00. the 9-5 ones have a fancy connectors on them rather than a single pin terminal.
DeLorean is offline
Old 04-03-2008, 01:09 PM   #15
liketheword's Avatar
I had this issue on my 9-3. It was due to the oil filter not being tight enough. Sinched her-up and wiped everything down. It's all right as rain. It sounds like your issue is intake manifold as suggested. If oil is coming from there at speed w/ the turbulance of everything that could explain the oil in other places.
Vitamin SAAB
liketheword is offline
Old 04-03-2008, 01:18 PM   #16
JK
JK's Avatar
On our 9-3 the presure sensor was simply not tight. There was oil everywhere, on the drive shafts, in the exhaust tunnel, everywhere.
So no, oil won't drip up, but it will fling up and get blown up.
JK is offline
Old 04-03-2008, 06:55 PM   #17
Im not sure what its malfunction is but its going to the shop. Just hit 80,000 on it and i think it needs new bushings so it couldnt hurt to take it in.
Mr. D is offline
