Bad Idle Problem - The Saab Link Forums
Old 10-22-2007, 05:41 PM   #1
Bad Idle Problem
I have a 99 9-5 auto that has started acting up today. When I start the car it idles for a second and dies. I can get it to start after 5+ times. Any idea what this could be caused by? I've replaced the TPS and throttle body in the last year with brand new parts. Could this be the maf?
99SAAB9-3 is offline
Old 10-22-2007, 05:52 PM   #2
Moonracer's Avatar
Hard to say , but it sounds like it might have gone into limp home mode. Are you getting any check engine lights? If not it could be a vacume leak also, but both of these should set a light.
Moonracer is offline
Old 10-22-2007, 05:58 PM   #3
StX221's Avatar
check for vacuum leaks, blown off intercooler pipes, limp home mode.
BUT, to me it seems like a CPS. (or is that what you meant by TPS)
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-22-2007, 06:01 PM   #4
I meant CPS One of the first things I replaced when we got the car, as it's my wife's.
Old 10-22-2007, 06:07 PM   #5
StX221's Avatar
can you hear the fuel pump prime for about 5 seconds or so when you turn the key to "ON" but dont start it?
Can you hear this same noise when the car wont start?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-22-2007, 06:34 PM   #6
I can hear it prime. I just swapped the DEI Casette and it seems to start a lot faster than before. Could this have been caused by a bad DEI?
Old 10-22-2007, 07:06 PM   #7
StX221's Avatar
With the whole DI system, anything is possible.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-22-2007, 08:17 PM   #8
Well, I guess I'll find out tomorrow or this week if this has cured the problem.
Thanks for all the imput
Old 02-29-2008, 08:44 AM   #9
This is still occuring, and I have replaced the CPS. It does it intermittantly, that's why I don't think it would be an air leak, and I also did a quick check of all vacum lines and nothing out of the ordinary. It also runs really well once I get going.
Old 03-01-2008, 09:22 PM   #10
I've got the same problem. I'm pretty sure it's the fuel pump showing its age. Especially since you already did the CPS. Here's a DIY.
Al's Red Wagon is offline
Old 03-02-2008, 04:22 AM   #11
ohlins8990's Avatar
Send a message via AIM to ohlins8990 Send a message via Yahoo to ohlins8990
This sorta happened with my dads 9-5. It was having trouble starting when it was under 40 degrees or so. Turned out to be the one way valve for the PCV system. It was also consuming a little oil with it messed up. But, he says it starts and idles better now, so you might check that its actually working.
ohlins8990 is offline
Old 03-02-2008, 12:59 PM   #12
I did the fuel pump already, but it didn't fix my problem. I've also switched out the Ignition Cassette.
Old 04-01-2008, 10:18 AM   #13
This just happened the last few mornings to me. It has been around 37 degrees the last 2 mornings and my 9-5 has had a little rough/blubbery start. Ironically I just ordered the PVC #7 upgrade. So, lets see if that cures it. Makes sense because it seems the original one way check in the PVC shoots the wrong way.
I just purchased it 1 month ago. It has 52k and I have been doing all of the maintenance on it. Oil, ATF, air filter etc. This weekend I will change plugs.
alexofc69 is offline
