rattling windows - The Saab Link Forums
Old 08-20-2007, 10:38 AM   #1
Trollerator
abdukted1456's Avatar
rattling windows
what would be possible casues for the front windows to rattle when partially open?
I am hoping it's a DIY fix for a cool fall weekend maybe some worn out rubber parts or something.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 08-20-2007, 11:57 AM   #2
StX221's Avatar
no idea. mine do this too. it is most prominent when closing the doors with the windows half down. horrible noise.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-20-2007, 12:10 PM   #3
Trollerator
I found a thread on SC, I don't know what they are talking about until I rip the doors apart though... no pics.
http://www.saabcentral.com/forums/sh...ad.php?t=70326
I need to make sure I have some double-sided tape before I start this one.
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-20-2007, 06:45 PM   #4
SPG-GASM's Avatar
Thats exactly it just remove your door panels and theres a strip of rubber that runs along the backside of the frame for the window. YOu can use tape or some type of adhesive to keep them up there.
SPG-GASM is offline
Old 08-20-2007, 08:25 PM   #5
Redfoxx's Avatar
Send a message via AIM to Redfoxx
mine raddle when they are partially open as well
Redfoxx is offline
Old 08-21-2007, 04:36 AM   #6
Cambiocorsa's Avatar
Send a message via AIM to Cambiocorsa Send a message via MSN to Cambiocorsa
Hmmm....not sure about the rattle, but when I am rolling up or down the front driver's side window there is a loud squeak, need to fix that. No idea what to do.
1999 Saab 9-5 SE Sedan
JakStoll Stage 3+
Cambiocorsa is offline
Old 08-21-2007, 05:08 AM   #7
Stephen Z's Avatar
Send a message via AIM to Stephen Z Send a message via Yahoo to Stephen Z
window
Supposedly there are rubber bushings at the bottom of the window where it attaches to the arm eEuroparts has them I have to do mine
2001 93 SE Vert
2001 95 Aero
1990 SPG
Stephen Z is offline
Old 08-21-2007, 06:54 AM   #8
StX221's Avatar
cambio, spray some silicone spray in the rear side of the window, right in that little slip that the window sits in. i sprayed mine a few weeks ago, and the problem with some squeaking/shuddering while the window goes down has been 100% eliminated so far!
now i just need to figure out whats going on with the rattling when the window is half open like this whole thread is about, and then i will have all the window situations solved!
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-21-2007, 07:51 AM   #9
Trollerator
read that thread on SC, sounds like some rubber thing falls out of place, you gotta take the whole damn door apart to get it, and apparently it's in a spot you really can't reach or see
I have a few car projects higher on the list so that one might have to wait a bit... if you do it, please take pics, I love them tutorials.
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-21-2007, 09:44 AM   #10
SPG-GASM's Avatar
its pretty simple like i metioned above you just have to remove your door panel and then put the rubber strip back into place. IT will be laying on the bottom side of the door. Its not that hard to do and you can see it fairly easily. Takes at most 15 mins a door.
SPG-GASM is offline
Old 08-21-2007, 02:11 PM   #11
Tikka's Avatar
Send a message via AIM to Tikka
Hmm, I thought I was the only person with this problem...
Which is fine. Because another guy got hit by a deer. Yes, a deer ran into a man.
Tikka is offline
Old 08-21-2007, 08:01 PM   #12
StX221's Avatar
yeah tikka, me too.
and i have had my doors apart more times than you guys probably turn on your radios. never have i seen anything resting on the bottom of the doors!
oh well, i will take them apart sometime and look
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-21-2007, 08:18 PM   #13
DeLorean's Avatar
haha, amazing, a "typical 9-5 thing" my 9-5 does not have! I have to say, no window rattle here.
DeLorean is offline
Old 08-23-2007, 03:22 PM   #14
jssaab's Avatar
Doh.. just jinxed yourself
jssaab is offline
Old 08-24-2007, 10:21 AM   #15
Fixed my wife's old 99 9-5 when she had that problem. Be careful removing the plastic trim the goes around the window frame. It cracks easily. Any tape will do to hold the lining in place for reassembly. The sticky goo used from the factory will probably still hold it fine. The problem with hers was the rubber guide falling out and a bad green roller. I would highly suggest replacing both rollers and liberally greasing them if you are in there. They are bound to fail, and removing the door panels is not something you want to do a lot, or you will get new squeaks and noises from them.
nbndtrain is offline
Old 08-24-2007, 10:31 AM   #16
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
mine did that in my 9000 too... so i just got rid of them.
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 08-24-2007, 12:10 PM   #17
Stephen Z's Avatar
So it is the roller/bushing ? There green ? I just ordered them(2) from eEuro
2001 93 SE Vert
2001 95 Aero
1990 SPG
