Front Disc Caliper brake removal Q - The Saab Link Forums
Old 05-12-2007, 07:14 AM   #1
jssaab's Avatar
Hyy anyone know what size the hex key ( is it a hex key) for removing the front caliper is? can't tell ( or see) to decide
jssaab is online now
Old 05-12-2007, 07:29 AM   #2
NahumCC's Avatar
Just start putting in hex keys till you get the right one. I used to know but can't recall off the top of my head.
2013 FR-S
NahumCC is offline
Old 05-12-2007, 07:33 AM   #3
jssaab's Avatar
Thnx got one jsut wnated to be sure it was hex 4 I strip it
Old 05-12-2007, 07:35 AM   #4
NahumCC's Avatar
You know thats the beauty of hex heads. I have yet to strip the head of any hex bolt.
2013 FR-S
NahumCC is offline
Old 05-12-2007, 08:17 AM   #5
mcrowley's Avatar
Its definitely possible, believe me. Work on enough bicycles (where almost everything is hex/allen bolts) and you'll find some that are stripped/rounded.
Usually what causes it is the wrench gets worn and starts to round...then it'll slip out of bolts...you get the picture.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-12-2007, 04:18 PM   #6
jssaab's Avatar
Got it, thanks, I tried to get the rotor hold screw off with a hex and it was torx ( that's what I get for not wearing my glasses to work on the car). Did not strp though got the torx in it and got it off ok.
The new rotor was a bear to seat, I think the hub is out of round. Had to put the wheel on and torqe it down to get the rotor to mate flat against the hub.
Could have been the the rotor was a bit too small of a hole ( dang aluminum rotor hat.)
Should have it all buttoned up tomorrow, it started to rain pretty good.
Old 05-12-2007, 04:34 PM   #7
DeLorean's Avatar
mine was the same way, I think it's just built up rust and anti-seize. Initially when I went to put the rotor on, I thought maybe I had the wrong ones or something I took a wire wheel to all the old rust, put on some fresh antiseize, and the new rotor dropped right on no problem. 100% perfect fitment. I think the issue is that the clearance for the rotor is so tight to the hub, any little bit of rust gets in there and makes a wall the new rotor can't get over.
DeLorean is offline
Old 05-12-2007, 04:45 PM   #8
CycM17's Avatar
damn. i just stripped the hex head on my surly singulator last night after it seized. kinda angry now. such an odd peice to replace.
CycM17 is offline
Old 05-12-2007, 07:30 PM   #9
jssaab's Avatar
Yeah I scraped and wired brushed till it was shiny buy it just seemed to hang up on two high spots right across from each other ( on the outer part of the hub where the wheel hangs not the flat surface). When O re-inexed the rotor the high spots moved so that's why I was thinking the hole in the rotor was the problem. I prolly shoulda filed it down a bit. It was a bear to beat off again after i dry fit it so I am going to hate it when it has to be replaced.
