manual tranny problem, reverse engages only intermittently - The Saab Link Forums
Old 02-19-2007, 07:14 PM   #1
so my manual transmission 9-5 has developed this problem where reverse engages only intermittently, usually when the car is rolling backwards. Otherwise it the stick won't move into the gate, and it feels like something is blocking it. When it does engage it does so smoothly and, and pushing the lever into 5th to re-align the dog teeth doesen't do anything (I'm guessing the shafts are paired 1st-2nd, 3rd-4th, and 5th-reverse, and when one of the first 4 doesen't engage moving it into the opposite gate always fixes it). Does this sound like a transmission issue or a shift linkage issue?
ACBarnett is offline
Old 02-20-2007, 04:06 AM   #2
FreStylMotox01's Avatar
one thing to try to ease the shifting would be the GS poly tranny mount. it is pretty nice, once i installed it, i had less problems getting into my gears and reverse.
FreStylMotox01 is offline
Old 02-20-2007, 01:34 PM   #3
NahumCC's Avatar
Make sure your pulling up on the reverse lock all the way. Not intended as an insult but I've found myself unable to get into reverse only to have the lock out not pulled up all the way. Also supposedly putting it into 3rd then going to reverse helps.......can't remember were I saw that.
2013 FR-S
NahumCC is offline
Old 02-20-2007, 02:15 PM   #4
WyldSaabMan's Avatar
first thing i would try is definetly aligning the shift linkage.
plus its only a 10 minute procedure...if that
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 02-20-2007, 06:36 PM   #5
StX221's Avatar
x2. i would say that 85% of shifting issues are solved by a re-alignment.
and the rest are solved by either a new trans, or an update to the MTF0063.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 02-20-2007, 06:46 PM   #6
drewz airflow se's Avatar
Take my advice take care of this now because i didn't and my reverse gear is non existent now.
^CLICK ME^
drewz airflow se is offline
Old 02-20-2007, 06:54 PM   #7
StX221's Avatar
yeah i didnt take care of 2nd gear and it disappeared.
....oh wait, it was the transmission that went in. (it was bad to start)
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 02-24-2007, 05:29 PM   #8
well by "intermittent" I meant that it only goes in when the car is rolling backwards, and while there is no grinding whatsoever and it goes into reverse nice and smoothly, it still only goes in when the car is rolling backwards.
My mech checked the linkage and said he saw something out of whack, but that it didn't fix the problem when he fixed it. He's not a saab specialist though so it might still be an issue that's outside of the box.
I'm just curious about where the parts I would have to play with to align the shift linkage and where they are located on the car. I'm also wondering what sorts of issues inside the box would cause reverse to only engage when the car is rolling backwards. It feels like the shifter is being blocked from going into the reverse gate by something.
Old 02-24-2007, 05:56 PM   #9
SPG-GASM's Avatar
we have a car that has the same problem at the shop we have realinged the linkage many a time and still no diference and we have also replaced the tranny with rebuild 2 was grinding and still the same problem, i beleive we have replaced the linkage also and still no difference i would have to say that it is a mount problem trans is sitting at just the wrong angle that it wont allow the linkage to pull it into reverse but im not for certain but like ferstyl said early and i beleive reverse is on its own shaft inside the trans also another area could be the actual gear changing mechanism inside the tranny(shifter forks) but i havent seen any problem with those but who knows
SPG-GASM is offline
Old 02-26-2007, 06:08 AM   #10
Nick Taliaferro
GenuineSaab's Avatar
The trans mount is not magic and will only help with the shifting under load because of binding. I wish it was the case. Sounds like you have a reverse syncro problem. There is a factory kit to address this.
http://www.genuinesaab.com/psi/files...ans-update.htm
Nicholas Taliaferro
GenuineSaab is offline
Old 03-03-2007, 05:25 PM   #11
know anything about 5th gear failing on these transmissions? I had my second gearbox failure in 2 months and it started again with 5th failing.
