9-5 Rear Suspension Bushing Replacement - The Saab Link Forums
Old 10-02-2019, 05:28 AM   #1
Troup's Avatar
Send a message via AIM to Troup
When searching for information about replacing the bushings for the rear control arms, I wasn't able to find a bunch of information. I thought I'd outline the work I've done on 2 different 9-5 Wagons.
There are 5 bushings on each side with a total of 10. I would recommend doing them all if you're going through the trouble to do any one of them.
Image of the bushings (Only need 2 of the long / narrow ones if you're doing adjustable arms)
There's the trailing arm bushing's towards the front of the car and 2 rose bushings upper and lower on the outer knuckle as well as 2 control arm bushings on the upper and lower control arms where they bolt to the rear subframe.
eEuroparts has a good blog post outlining the reasons for replacement. Here's a link to the post:
https://www.eeuroparts.com/blog/7473...ension-issues/
Image borrowed from eEuroparts to diagram bushings:
OEM Part Numbers for the Bushings:
Outer bushings: 4567244
Inner bushings: 4566378
Trailing arm bushings: 12781136 (I highly recommend the Powerflex trailing arm bushings for the price)
To Start:
- Remove the wheel and expose the rear trailing arm.
- Remove the 3 18mm bolts that hold the trailing arm to the front of the rear
wheel well
- Remove the 21 mm shock bolt
- Remove the 2 18mm bolts that hold the control arms to the trailing arm
- Remove the emergency brake cable from the brake mechanism
- Remove the 10 mm bolt that holds the emergency brake cable bracket to
the trailing arm
- Remove the 16 mm bolt that holds the sway bar link to the trailing arm
At this point, you can drop the trailing arm to the ground and have better access to the 15mm (maybe 16mm?) nuts / studs that hold the rear hubs to the trailing arm. There are 6 nuts that you need to remove here. There are 2 that hold the bracket that holds the brake line and wheel speed sensor to the back of the hub, then there are 4 that actually hold the hub to the trailing arm. However, the 2 that hold the bracket on are the on the same stud as the ones that hold the hub to the car. Be sure to remove the connector for the wheel speed sensor to the hub before you drop everything so the wiring does not get damaged.
I make this point because I got super confused swapping a hub bearing awhile back not realizing it was laid out this way.
Now to replace the bushings:
Trailing Arm Bushings:
To get the trailing arm bushing out, I used a 1.5" hole saw to drill out the center and then a reciprocating saw to carefully cut the metal race out. If you have a press, you could also pop it out super easily.
To install the Powerflex bushing, just apply the supplied grease and slip it in. Install the center metal sleeve.
Trailing Arm Rose Bushings:
I have done this 2 different ways now. The first time, I used a press on everything. A press is great for every bushing except for the lower trailing arm rose bushing. The angle on the arm that is made to accommodate the rear shock bolt makes it extremely difficult to fit any type of receiver in there. The press also has to be able to fit the length of the trailing arm inside which I found to be difficult. I ended up paying a shop to do this one bushing the first time. The second time, I purchased a specialty tool. I highly recommend using a tool that has the proper sized pieces to push and receive the bushing. I found a lot of options overseas.
Here's a picture of the tool I used. I got it from the UK for $50 USD shipped:
It's a great tool, but the supplied threaded parts stripped despite my best efforts with grease and heating up the bushings. I used some random Saab bolts I had laying around and they worked better. You will need a threaded rod / nut combination to do the lower bushings on both sides due to the clearance issues. You cannot fit a bolt through.
Link: https://www.ebay.com/itm/Opel-Vectra...72.m2749.l2649
If you have a press / receiver kit, here is the measurement of roughly the OD you would need to push the bushing through
Use the tool or press to get the rose bushings out:
Some heat applied to the trailing arm will help get the bushing out easier. Ideally you'd heat it up before you put the tool on to avoid expanding the tool as well. I also used PB blaster a few days prior to loosen up corrosion, but I don't know how much that actually helped.
To press in the new bushings, I'd recommend putting them in the freezer a couple of days in advance to contract them. I also heated up the trailing arm prior to installation to expand it to make installation easier. Use the tool in the reverse way to push the bushing in. Also use some kind of grease on the bushing.
Repeat on for upper and lower on both sides.
Finished product:
Upper and Lower Control Arms:
The inner bushings on the control arms are much easier to work with than the outer rose bushings. If you have a press, definitely use it to make short work of these bushings. Make sure to use a block or something to maintain the shape of the control arm as you press a new bushing in. The part that houses the bushing is very thin and can bend easily. I still need to do these bushings on my second wagon and don't intend on using a press. I will update how I end up getting it done.
If you want to have adjustment of the camber in the rear, you have the option of installing adjustable rear control arms on the lower mount. I installed them on the first wagon I did. I love them, but I haven't figured out an effective solution for the rear headlight leveling sensor that mounts there yet. If you install these, you only have to replace 1 set of upper control arm bushings as the new adjustable arms will come with new bushings installed.
There are many brands of the adjustable lower control arms. I went with Moog. PN:
Install the trailing arm in the reverse order you took it out and torque to specifications. Reinstall the trailing arm bushing bracket and torque the bolt before you install the arm back on the car. You can't torque it once it's installed. Torque spec is 90 Nm + 60 degrees
Additional Rear Suspension Torque specs per the WIS:
Rear Hub Assembly Instructions/ Torque Specs:
Other Job Notes:
** The second time I did this job, I used trailing arms from a junkyard car because I wanted to have them ready to install and I wanted to have trailing arms that weren't rusty. This obviously isn't necessary, but will help divide the work up.
**Instead of removing the wheel hub, you could alternatively just remove the brake caliper. However, consider that there may be shims that were previously installed between the hub and trailing arm to account for negative camber. If you're installing adjustable arms, you're going to want to remove these shims. Or even if you're not, I'd prefer to remove them, check alignment, and go from there.
**There are many ways to disassemble the suspension to do this job. If you want to have alot of room to work and do everything at once, you can drop the entire rear subframe. I did it this way my first time. The second time I did the control arm bushings separately from the rose bushings, so I just took the arm off.
-1992 9000 T5
-1994 9000 Aero
-2004 9-5 Aero Wagon - Espresso Black
-2004 9-5 Aero Wagon - Glacier Blue
Troup is offline
Old 10-02-2019, 06:47 AM   #2
9Kwrecker's Avatar
This is excellent, I'm glad you put it all in one spot. It'll be nice and easy for me to reference when I finally decide to replace this stuff on my wagon.
Would you say it did anything to help with the "saggy" look that 9-5 wagons usually have in the back?
88 900T
91 9000T
91 MCY Vert
02 Aero Wagon
07 9-3
94 Miata
05 Legacy GT
9Kwrecker is offline
Old 10-02-2019, 07:45 AM   #3
Troup's Avatar
Heck yeah. That's the goal. Gotta keep the technical stuff alive as Saab mechanics wear thin. Power to the DIY'er.
In my opinion, yes. It definitely helps. Especially if you do the adjustable arms. The arms take out any negative camber, regardless of the cause, and makes the wheel straight in the wheel well.
I will say that the outer bushings are designed really well. Of the ones I've taken out, they've only been slightly clickly when trying to rock them back and forth.I'm not sure that these ones contribute a bunch to the sag, but I imagine that even a little bit of wear on these will cause some degree of negative camber.
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 10-02-2019, 07:51 AM   #4
Troup's Avatar
Before:
After:
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 10-02-2019, 08:09 AM   #5
9Kwrecker's Avatar
So no adjustment to the coils in those pics, only difference is the bushings?
That is the one that you put the coils in right? So hard keeping your simultaneous wagon builds straight lol.
88 900T
91 9000T
91 MCY Vert
02 Aero Wagon
07 9-3
94 Miata
05 Legacy GT
Old 10-02-2019, 08:15 AM   #6
Troup's Avatar
Yes, the only difference is the bushings / adjustable arms. Both of those pictures are old and are with the stock Aero springs and Bilstein B8's that are now on the Glacier Blue wagon. The after picture is the day I finished up the work on the rear suspension bushings.
Yeah I can't keep them straight myself sometimes. I'm basically redo-ing everything on the blue wagon that I just did on the brown wagon last year. Water pump and silicone hoses are next.
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 10-02-2019, 12:48 PM   #7
Cark's Avatar
Very nice work!
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 10-09-2019, 07:11 PM   #8
srp
srp's Avatar
Send a message via AIM to srp
Awesome write up. Thanks for taking the time to put it together!
srp is offline
Old 01-10-2020, 05:07 PM   #9
thewheell22's Avatar
Terrific work and write up! I'm starting this in 2 days on my '02 ARC Wagon. Just finished the whole front-end and subframe bushes. I think I'm going the 'drop the subframe' route. Your write up is encouraging. Thanx again!
thewheell22 is offline
Old 01-13-2020, 06:17 AM   #10
Troup's Avatar
Thanks!! Glad to hear it. You'll have a new car when you're done.
When making this write up, it had been a over a year since I had done this the way where you do not drop the rear subframe. When I was pulling bolts the other day at the junkyard, I remembered that there is an annoying thing with the inner control arm bolts. Because of the orientation of the bolts, you must either drop the gas tank slightly to be able to back the bolts out, or just drop the subframe entirely.
I've heard that it was done this way so that the bolt won't puncture the gas tank in the event of a collision. It would make much more sense from a mechanic standpoint to have the bolt installed the opposite orientation.
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 01-13-2020, 06:20 AM   #11
Troup's Avatar
Originally Posted by Cark View Post
Very nice work!
Thanks for the compliments! I hope it helps a bunch of people in the future.
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 01-16-2020, 05:59 AM   #12
Troup's Avatar
I powdercoated my rear subframe on one of my wagons recently and had to press the bushings out before hand. I pressed new ones in after powdercoat and figured I'd share the info. There are 4 bushings that all look similar. 2 are one PN and the other 2 are different. They press in from the bottom of the subframe facing up towards the body of the car. Here's a picture of how they should be installed. Use the exhaust hanger for reference. The orientation in the picture is how it's positioned when it goes on the car. (trailer hitch at top of picture)
*Note that these PN's are for 2002-2009. I believe they are different for earlier year 9-5's
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 02-08-2020, 12:18 PM   #13
Thanks Troup. I finished my rear suspension sins the subframe bushes or adjustable arms. I paid the local Les Schwab tire dealer to press out/in bushes, tl was $90, not bad I thought. Funny thing, I had them re-allign (had them do it after the front end 1mo before). After sitting for what I thought was a pretty long time and hearing a lot of banging, the tech comes out to say he's done, all good but the rear camber was still neg 2 degrees and he couldn't get the hubs off after "removing all 4 nuts!", so he wasn't going to charge me for the alignment! I had to laugh and told him he could've asked, there were 2 more nuts hidden in there but not to worry. I went home and put 2 3mm shims to move pos on the camber and I'm callin it good. Can't say the ride is much different now the rear is done, but after doing the front a month ago I'm still amazed, Man it's like a new car! Again thanks for your original pics they gave me more confidence to take this on for the first time. Ride On!!
Old 02-24-2020, 01:42 AM   #14
Troup's Avatar
Hey, No problem! I'm glad the write up was able to help you out. $90 isn't bad at all I think. The first time I did this job, I struggled using a press to press out / in the lower rose bushings that are in a horrible position. I ended up paying a shop $100 to do those alone. Where I am currently living, it's very difficult to find a shop that is willing to go out of their way to do anything challenging. I think the shop that ended up doing it was stop number 6-7.
To be fair, I learned about the extra 2 nuts on the rear hub the hard and ignorant way. But I was also working on my car in a parking lot at the time and not on a lift
I've had some hit or miss experiences with alignment techs myself lately. I had just redone the rear suspension on my Glacier Blue wagon and was able to get it perfectly in spec at my local Firestone a couple of weeks ago. I decided I wanted to throw on all of the powdercoated stuff that I had laying around and tore it back apart. Of course now they can't get it as good as it was before I messed with it. That's the way it goes I guess. No one wants to take the time to play with all the adjustment that is available. Luckily I have the "Lifetime Alignment" at Firestone, so I'll probably unbolt the trailing arm bracket, knock the toe out, and take it back to them so they can try again
-1992 9000 T5
-1994 9000 Aero
Troup is offline
Old 02-29-2020, 03:06 AM   #15
GriffinWolf83's Avatar
I need help
SEARCH IN THE CURRENT
AND SHOW ME
IndexSaab New 9-3 '03+ ForumCar Problems? New 9-3 Only
GriffinWolf83
online
Join:*Feb 2020Posts:*5
Feb 22, 2020* #1
Central locking fob
Hi everyone, first time owner of a Saab and first time on this forum. I have replaced the battery on my fob and the circuit board looks in good condition but the fob wont lock or unlock the car. Putting the key into the lock works but not the remote, any ideas would be great.
adidas_007
Join:*Nov 2004Posts:*1170Pennsylvania
Feb 23, 2020* #2
model & year? Sometimes you need to keep pushing the lock / unlock button till it relearns.
You can also find the owners manual online, if you don't already have one.
GriffinWolf83
online
Feb 23, 2020* #3
Tried that and PING! It now works, thank you 😁 Another question if you don't mind... I have sound coming from the dash speakers but nothing from the doors or the boot. All speakers and wiring are present, I've looked under the panels in the boot sides, under all of the seats and the foot wells - driver and passenger side but can't find an amp, not even any sign there ever was one. My Saab is a 2.0 se 1998 model. 2 days solid I've been trying to figure out why I have no sound but I'm at a loss 😔
adidas_007
5 days ago* #4
I'm not an audio guy. Other then trying the balance and fade. Good luck
GriffinWolf83
online
5 days ago* #5
Thanks, I have tried that but still nothing, I presume I don't have an amp, I've checked the back of the stereo and all 3 plugs are in, is it at all possible for all rear and front speakers to break after 20 odd years?
GriffinWolf83
online
1 day ago* #6
Speaker
So just an update on my speakers, I borrowed a spare house speaker and one by one plugged it into the car where the speakers weren't working and voila! It worked. Turns out all my speakers were 21 years old and completely dead. Put new ones in and now I have sound 😁
GriffinWolf83
online
Hazards randomly going off
Hi, my hazards randomly flash when the car is locked up. It's a 1998 model and I have had every panel, sidewall and carpet up but the is no onstar so I was hoping someone on here can shed some light on what the problem might be.
GriffinWolf83 is offline
