Does not start-Twice & Lock anti-theft system? - The Saab Link Forums
Old 08-29-2018, 12:59 PM   #1
Exclamation Does not start-Twice & Lock anti-theft system?
Help - My 2000 9-5 AERO was cranking but not starting. I had it towed to shop suspecting fuel delivery issue but according to technician the anti-theft system locked out fuel and spark. He asked me to pursue replacing the Twice unit (found under driver seat) and the locks that goes with it.
Has anyone encountered or know anything about similar issue?
MOD2K95AERO is offline
Old 08-30-2018, 08:38 AM   #2
It's not terribly uncommon.
There are a few ways to go about repairing it, and buying a new TWICE/Key set is pretty common.
A quick search will bring up lots of threads. I'm pretty sure you can replace just the unit and marry it if you're handy with the tech2
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 08-30-2018, 10:36 AM   #3
DrewP's Avatar
^^^That, you don't have to do the lock cylinders, it's much cheaper and easier not to. What you can do is get a TWICE with either a key mated to it, or a TWICE that comes with the little transponder chip that you pop into your existing key, then when you marry the TWICE to the car you will reprogram all the existing keys to match the replacement TWICE. Lots of writeups on this, but you'll need a tech with a Tech2 who knows the procedure to do it.
Read: https://www.lostsaabkeys.com/Removal...sSaab9395.aspx
DrewP is offline
Old 08-31-2018, 01:09 PM   #4
That's my problem, I towed car thinking it was a fuel delivery issue and since I just moved to this area and do not have a local SAAB tech yet. The tech working on my car only has the Tech 1 tool but he said there is no need since I can just replace the whole sytem. Asked me to search for used Twice with locks online .
Old 09-04-2018, 04:56 AM   #5
Question Options
So believe these are my options as it were: ( please advise me )
1. Find nearby SAAB specialist and re tow (loose money with local tech and tow)
2. Purchase my own TECH 2 ( after reviewing TECH 2 forum - questionable)
Or
3. Replace entire Twice and lock components ( avoid needing Tech 2 as per local tech suggestion )
Any suggestions?
I love my SAABs but this presents a whole new problem
Old 09-04-2018, 09:51 AM   #6
DrewP's Avatar
If you replace the TWICE module with one from another car it still needs programmed via Tech2 regardless is you use a used unit with matching keys, or a rebuilt or refurbed unit. The only way you will not need access to a Tech2 to mate TWICE to the rest of the car is if you send out your unit for repair and then reinstall it to the car. TWICE is coded to DICE and ECM with the VIN number of the car and immobilization is disabled during programming.
Your options are 1 & 2 that you have added above, and 3rd is following the instructions here and having these guys see if yours is repairable: https://www.lostsaabkeys.com/Removal...sSaab9395.aspx
DrewP is offline
Old 09-04-2018, 01:16 PM   #7
Thumbs up
Thanks DrewP
Old 09-05-2018, 08:13 AM   #8
Now, if you're handy with a solder iron, it may be worth it to pull the cover off the unit and check it out, internally. it may not have any blown components, any may just either have corrosion on the pins, or have a cold solder joint.
I literally just went through this with my ng900.
I tried everything, hardware-wise, and it turned-out that it was just a couple cold joints.
I had given up on it and ended up paying someone $400 for something I could have done for free.
Craig R.
g96nt is offline
