9-5 Aero Power Steering Pump, Pulling the Pulley Tips? - The Saab Link Forums
Old 02-04-2017, 05:21 PM   #1
Drew In Houston
My daily driver +213k 2003 Aero needs a new power steering pump.
I bought a rebuilt ACDelco unit: https://www.rockauto.com/en/partsear...rtnum=19319307
But I learned that they come without the pulley attached and the originals are pressed on. I used a puller and bent my pulley, even after heating it. I have another used pump here that's soaking overnight to try to pull the pulley on that one.
Are there any tricks to pulling these pulleys without damage? Has anyone successfully done it?
Trionic3000 is offline
Old 02-05-2017, 05:45 PM   #2
Drew In Houston
I have an update on this. As it turns out, there's a collar on the center hub of the pulley that I didn't see, which as I research, I think is typical for PS pump pulleys. The OD on the collar is about 1.168", the internal diameter is recessed so I couldn't measure it.
Anyways, I'm trying this Lisle kit to pull it: Lisle Corporation
I have a nice small 3-jaw puller that I tried for the heck of it on the hub collar on pulley that I bent, it just chipped the collar face off, they're pressed on there pretty tight. This puller kit wraps the whole way around it, will see.
Old 02-06-2017, 06:01 AM   #3
Wagon Shaggin'
Saabeh's Avatar
Interested to see how this pans out.
Saabeh is offline
Old 02-07-2017, 05:47 PM   #4
Drew In Houston
It works great! I only had about 10 minutes and checked to see if it fit, it did, so I just turned it off. It's surprising how tight the press is. The shaft itself is tapped in the center to pull the pulley back on, that part's not done yet, but I don't think it'll be a problem.
