Struggled with cold morning starts, but strong crank, No start now - The Saab Link Forums
Old 05-17-2016, 05:43 AM   #1
Unhappy Struggled with cold morning starts, but strong crank, No start now
Hey guys I recently got an 2003 Saab 9-5 Linear with 109k miles on it.
It had a bunch of repairs done to it before I put it on the road with one being the fuel pump, so I don't think its that.
It was having troble starting last week occassionally and it would sound extremely rough to the point that it wasn't firing on all cyclinders at inital start up so I would just turn it off and then restart it and it would fire to life on all cyclinders. My garage thought it was the battery as it was over 3years and the car sat alot before it got to me. So they gave me a new one and problem went away.
Yesterday it struggled but then started right up on second key turn.
Went out to start it today and nothing but attempting to crank over with no sign of it firing. There are no CEL codes came up on my computer.
UPDATE: Just tried to start again and it made a sound like it wanted to crank over but didn't twice. still no start
Side note any good Saab mechanics on Cape Cod or South Coast of Massachusetts?
Rob2003-9-5-Linear is offline
Old 05-17-2016, 08:10 AM   #2
okay- so... Replacing the fuel pump almost always means broken hard lines if the mechanic is not a saab-er. Occasionally, people use non-submersible fuel line. Both of these usually end in a total failure, not intermittent.
Alternatively, if the check-valves fail, it can take 2 cranks to fire-up a 9-5. The first is really just priming the lines that would normally be full of gas, but aren't. This is common, too.
The misfire at start-up is fairly common. my car's done it occasionally for years.
It's just the ECU trying to sync the cranks sensor and Ignition cassette.
let it idle for 30-seconds, and it'll run fine. a blip of the throttle can fix it, too.
If it's getting worse, it may be the crank sensor. When it's not starting, keep an eye on the tach. it should bounce a little while cranking. If it's not, the ECU isn't getting a CPS signal.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 05-17-2016, 08:42 AM   #3
Thanks for reply.
The shop that did all the work on it with the fuel pump are saab specialists. They have done all the work on my familys Volvo's and Saab's in the past. I trust them that they did the right thing when they replaced the fuel pump. I have spoken with them on the phone and from my diagnosis to them they believe it is the Direct Ignition cassette. The Tach does register alittle RPMs when cranking.
There is no starting of it at all currently and when it misfired on start blipping the throttle had no effect of correcting.
Unfortunately I moved away from family so I am in the process of hunting a shop to do the work or at least diagnose the issue.
I am waiting to see what the shop I dropped it off at just now believes the problem is.
Again thank you for the reply.
Old 05-17-2016, 01:08 PM   #4
Garage just called it is apparently the fuel pump... Maybe the first garage didn't replace fuel pump with the right line
Old 05-17-2016, 01:09 PM   #5
If it's the cassette, it's a driveway fix. Just order the part and chuck 'er on
Craig R.
g96nt is offline
Old 05-17-2016, 01:11 PM   #6
Possibly. Or, they didn't use the right clamp.
Is it going back to the first shop? Seems they should warranty their work
Craig R.
g96nt is offline
Old 05-17-2016, 05:13 PM   #7
No its not going back to the first shop they are almost 300miles away so the tow wouldn't be economical.
I will let them know of the issue though and they have always been extremely good in these and fair situations when they happen once in the past.
Old 05-19-2016, 07:46 AM   #8
Wagon Shaggin'
Saabeh's Avatar
I have a 2002 9-5 Aero where all the fuel in the rail evacuates back into the tank over night. Takes quite a bit to start it in the AM. The check valves are less than a year old PPS. Kinda butthurt about it.
Saabeh is offline
Tags
cold start, crank position sensor
