Car Problems? 9-5 Only If you're experiencing problems with your 9-5, post your question in here. CEL Code or GTFO! |
LinkBack | Thread Tools |
#1 |
Oil leak and belt slippage
I had a water pump fail about 3 months ago. After I changed my water pump I began to have problems with my belt slipping. I also noticed oil around the pulley area near where I believe the head gasket is. I also am not sure if whether or not my belt tensioner needs to be replaced as well. Attached is a pic of the area where my leak is coming from. I don't want to just throw money at the problem and not make it go away.
Sponsored Links | |||
#2 | |
Wagon Shaggin'
Is it the front of the valve cover gasket? If not it may be a little lower, you could try to retorque the cylinder head bolts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Quote:
#3 |
Sponsored Links | |
Thread Tools | |
