Stage 3 brew city boost fuel cut - The Saab Link Forums
Old 11-02-2015, 08:13 AM   #1
So I have had a stage 3 bcb tune in my 2005 Saab 95 aero and I have been trying to track down a problem I have had for a while a lot of the time during hard acceleration it will hit a fuel cut, or at least that is what I think it is. The needle on the boost gauge will go to the end of the red then 8 times out of 10 it will make a loud backfire type noise and loose all of the boost, I don't know how to go about fixing this problem I have seen others with the same issues but I have been able to find a solution. I don't know if I should go with a different tune or what, any input is appreciated the car has all the supporting mods 3.5fpr, intake 3in downpipe, silicone vacuum lines, forge dv, and ngk plugs gapped to 1.0mm
Vtsaab95 is offline
Old 11-02-2015, 09:05 AM   #2
Harvey's Autohaus's Avatar
I've had 2 "RaceCats" @ a few T7 cats clog up & drive me crazy until I figured it out, If it Missfires under full boost @ high RPM's start looking closely at the ceramic inside.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 11-02-2015, 10:54 AM   #3
Drew in Houston's Avatar
It's kind of guess work without a little more info. If you have open SID take a look if the misfire counts go up. Cooler weather gives a denser charge, your spark may be getting blown out or it could be leaning out because it's now running in a different area of the fuel calibrations, or the opposite and too rich. You could try a tighter gap, like 0.8, I've ran as small as 0.6mm and see what that does. Do you have a wide band AFR signal? Or...it could be the cat like Harvey wrote, or it could be ??
Drew in Houston is offline
Old 11-02-2015, 04:35 PM   #4
I just figured out how to enable an open sid and after doing a 3rd gear pull my missfire count went up I'm not entirely how to tell what everything means or what numbers i should be seeing as I just figured out how to enable it this evening is there anything specific I should be looking for?
Vtsaab95 is offline
Old 11-02-2015, 05:23 PM   #5
Misfires went up while under load--in the area where you noticed the issue before? Or after you lifted the throttle? It's normal for it to count some mifi's during lift throttle. How old are your spark plugs? It's free to pull them and close the gap a little to see if that makes a difference.
You might consider installing a wide band O2 sensor, that would really help narrow things down. Maybe your fuel pump is slowly failing and it's becoming progressively worse and unable to meet full demand and maintain fuel pressure under load causing a lean condition and that's why it's bucking around--I've had that happen where a pump works fine under low loads, but then progressively failed over time. Hooking a fuel pressure gauge and taping it to the windshield and then driving around is one way to get a general idea if something like that's going on.
You'd have to spend some time researching what each code represents, it's actually pretty cool and a lot of people have put in a lot of hard work to make it available.
Old 11-03-2015, 05:18 AM   #6
Yes misfires went up when I recreated the problem, I will take out my spark plugs tonight and do a tighter gap I will let you know if the problems still there
Vtsaab95 is offline
