Exvessive Drain on Battery; TWICE disconnect - The Saab Link Forums
Old 10-11-2015, 08:16 AM   #1
Battery will not stay charged unless making long trips. After a period of short trips or no use the battery fails to start the car. Amp-meter (set on 10 amps) reads 0.13 amps (which is 130/1000 or 130 milliamps-- I think) while parked in the garage.
I pulled fuse #17 (Dice/Twice, MIU and Trionic) and the amp-meter reading dropped zero with an occasional 0.01.
Is 130 milliamps too much drain? If so how do I disconnect the hungry user and keep my dashboard electronics, main instrument unit and "Trionic"? I can live without the TWICE.
Stephen
jsmabrey@gmail.com is offline
Old 10-11-2015, 02:07 PM   #2
Yes that is to much of a draw. 50mA is the spec, but it can take up to 30 mins for it to drop that low. You can't remove twice it is needed for the immobilizer to work. Before you get to involved in searching for a draw make sure you wait at least 30 mins with the amp meter installed.
Drifting-FB is offline
Old 10-12-2015, 06:20 AM   #3
Thanks for the help. I did not mention that when I first connect the amp meter the reading is 2.5 and sometimes 3.0. Then the reading falls slowly over the course of 5 minutes to 0.13. I have not waited 30 minutes connected but I'll do that and report the results. Stephen
Old 10-12-2015, 08:16 AM   #4
I waited 40 minutes and the reading fell to 0.01 - 0.02 which is 10 to 20 milliamps. This is well under 50mA. If the drain is below allowable limits that leaves only the storage or charging system to blame for the repeated failure to keep the battery fully charged or perhaps a drain that is not present at all times.
The battery and alternator have been checked twice (AutoZone) without any findings. The 7-year battery is 4-years old and the alternator is OGM (Mileage 68,000).
I have heard that the ignition key-lock is at times a cause of drain. This might cause the lack of pattern of the failure when combined with short trips and no-use periods.
Got any ideas?
Stephen
Old 10-12-2015, 12:57 PM   #5
DrewP's Avatar
The ignition cylinder can cause that if the lock tumbler doesn't "pop" back up when you remove the key. Make sure yours clicks up every time you remove the key. If it doesn't lubricate around the outside of the lock tumbler lightly with WD-40.
DrewP is offline
Old 10-12-2015, 01:48 PM   #6
Thanks to both Drifting-FB and DrewP.
I've noticed that beeping (don't forget your key) continues sometimes even after I remove the key and most times it doesn't. When it continues I re-insert the key and then take it out and the beeping stops. Could be the same "pop-up" problem.
I'll lubricate and then watch the lock tumbler closely.
Stephen
Old 10-12-2015, 02:50 PM   #7
DrewP's Avatar
Yes, that's the problem.
DrewP is offline
Tags
dice/theft warning system, excessive battery drain
