apparently, I suck at brakes. Picture included. - The Saab Link Forums
Old 04-21-2015, 03:38 PM   #1
so, I just replaced a caliper and all 4 pads after a caliper seized.
I used the same springs I used before the seizing.
after putting it together, I get this:
(there's an inside inch where the pads aren't cleaning/contacting the rotor)
It's happened before when I was in a rush and put the springs in wrong, but they're fine now. Anyone have any suggestions?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-21-2015, 04:35 PM   #2
Cark's Avatar
Just to clarify these are fronts on a NOT Aero/308mm setup???
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 04-22-2015, 06:11 AM   #3
They are.
308mm rotors, aero brackets, and the same normal pad I've always used.
The weird thing is that the pad is actually covering the rusty area, but there's no pressure being placed, so it's staying rusty.
I'm going to pull the calipers and grease the pins/scrape where the pads rest.
the last time it happened, it was because I put the springs behind the "ear" of the caliper bracket. this time, everything's in there correctly.
Craig R.
g96nt is offline
Old 04-24-2015, 07:34 PM   #4
You sure the springs are right as shown in the pic? I didn't understand if you corrected it or not.
The springs in the pic don't look right to me. Perhaps it's the angle, maybe they've been bent out of shape too much?
Ref:02.06.2007: Saab 9-5 Front Brakes - photo.platonoff.com
Tboy is offline
Old 04-25-2015, 05:00 AM   #5
Yeah. ya know.. you might be right.
It's possible they're bent too much. I did re-use them. Perhaps I'll order some new ones, anyways. It's not like they're expensive.
Craig R.
g96nt is offline
Old 04-25-2015, 07:33 AM   #6
oliversexpedition's Avatar
Not sure that newer springs is going to solve the problem, was it making noise/rattling?
Can you micrometer aka mic the brake rotor? Might be a low spot on the inside, not sure if they can be turned?
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 04-25-2015, 11:41 AM   #7
I don't have a gauge. It brakes fine, though. and it was 100% fine until I swapped pads. The other side is doing the same, but the "strip" is narrower.
I will probably pick up some springs and grease tomorrow when I get the starter.
I do see that the spring is sort of floating. It's not pushing down on the pad at all.
Craig R.
g96nt is offline
