manual tranny reverse synchronizer? - The Saab Link Forums
Old 03-30-2015, 05:13 PM   #1
I cant get 2004 95 to go into reverse unless car rolls back by gravity.
Is it synchronizer, does this require transmission rebuild, do i keep car w 130k miles,all other gears fine. I've driven it for 5 k miles w this paking facing uphill
roet is offline
Old 03-31-2015, 05:53 AM   #2
Wagon Shaggin'
Saabeh's Avatar
I would start with a fluid flush. I bet its original fluid. Where are you located?
Saabeh is offline
Old 03-31-2015, 08:48 AM   #3
Drew in Houston's Avatar
Can you start it in reverse and the clutch pedal pressed in - and back up like normal - then press the clutch in and knock it out of reverse? If you can't do that, I'd check shifter alignment, and if it's not that, seems like there may be larger issues.
Drew in Houston is offline
Old 04-01-2015, 11:11 PM   #4
93viggen's Avatar
Had a Viggen once that did this, ended up needing just a clutch assembly. Try Drew's suggestions first, though. If it was just the synchro, blocker ring or gear it would still try to go into gear but it would be grinding. Could be getting jammed, but like Drew said start with the simple.
Using waste to make haste!
93viggen is offline
Old 04-02-2015, 05:35 AM   #5
Saabeh did you ever figure out your reverse issue or are you just putting it off till you need to totally go in and rebuild it?
Snowcat77 is offline
Old 04-02-2015, 05:48 AM   #6
Wagon Shaggin'
Saabeh's Avatar
Still the same. I get it into reverse every time, just takes some "finagling." I have a gearbox in the basement ready to be installed some day.
Saabeh is offline
